Author Topic: VW Transmission ratio chart  (Read 5868 times)
March 13, 2015, 11:27:57 pm
starrd
  • 128
« on: March 13, 2015, 11:27:57 pm »
If you post/send me your transmission tooth counts, differential gear tooth counts, tire circumference in cm's, max RPM, Car model, transmission code and required units (MPH or KPH)
I will create and post the chart for it as per example below:
Also, once I have it done, I will make an exe available so you can create your own and play with different ratios etc.
« Last Edit: March 14, 2015, 08:20:36 pm by starrd »
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #1March 14, 2015, 02:53:52 am
golfmk1tdr
  • 53
    • My car's forum thread
Re: VW Transmission ratio chart
« Reply #1 on: March 14, 2015, 02:53:52 am »
That's the gearbox I have :)
Interesting that shift rpm points go higher every shift, that means I would better look at speed gauge rather that rev for best drag race results, or maybe get gearbox where shift points are alinged  ???
Could you increase engine rpm on chart to 5000? I think my 1.6 TD should pull to 5000 ok (also I want to see if it confirms my top speed calc.  :P)
1.6+holset MK1 Golf TDR /TurboDieselRacing
(no GTD because GT is grand tourismo and there is nothing grand and touristic in my stripped out lowered beast)
Reply #2March 14, 2015, 10:37:35 am
starrd
  • 128
« Reply #2 on: March 14, 2015, 10:37:35 am »
Here you go:
