Author Topic: Cheap ebay dial indicator timing success  (Read 2321 times)
February 21, 2015, 10:18:19 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« on: February 21, 2015, 10:18:19 pm »
Today i finally got around to checking the timing on my 1.6TD (retarded ~.1mm from where it should be) and adjust it.
So i finally got to try out my cheap eBay dial indicator, which you may remember from this thread:
http://www.vwdiesel.net/forum/index.php/topic,35381.msg334642.html#msg334642
maker name is "SHARS" - costs $20.
The question had been asked if, after inserting it into the adapter, does it have enough travel?
Yes. Yes it does. I have the ebay timing adapter. I used the long timing adapter configuration (both barrels, long tip) and gave it 7mm of preload (out of 10mm total travel) and had no problem clamping it with the screw in the side of the adapter.
of course, it started snowing while i was working on this, and then i had to leave to score more Trung Nguyen Gourmet Blend Coffee from the vietnamese grocery. I still want to re-verify my timing now that everything is buttoned back up and the timing locks are out.
Reply #1February 22, 2015, 05:53:15 am
Re: Cheap ebay dial indicator timing success
« Reply #1 on: February 22, 2015, 05:53:15 am »
good, I was one wondering for sure.
Reply #2February 22, 2015, 07:59:58 pm
TimpanogosSlim
  • 590
« Reply #2 on: February 22, 2015, 07:59:58 pm »
It occurred to me after some thought that it's possible that in the official style timing adapter, to get it to lock into that kind of adapter you might have to insert it so far that it won't have enough travel.
In that case, you could just grind a few mm off of the pin of the adapter.
