Author Topic: 86 Jetta speedometer help needed.  (Read 7764 times)
January 31, 2015, 07:37:16 pm
30dodgeboy
  • 12
« on: January 31, 2015, 07:37:16 pm »
Working on a 86 Jetta with a AGS transmission.  Speedometer reads 10-15% faster than car is going.  Tires are P195/60R14, plenty tall.  Checked speedometer gear, it has the white gear in it like it should.  Is there any other things to check?  Could speedo head of the cluster be the problem?
Reply #1January 31, 2015, 07:51:14 pm
Re: 86 Jetta speedometer help needed.
« Reply #1 on: January 31, 2015, 07:51:14 pm »
Is the odo accurate?
Reply #2January 31, 2015, 09:26:51 pm
30dodgeboy
  • 12
« Reply #2 on: January 31, 2015, 09:26:51 pm »
No, the ODO reads too fast too.
Once I got the speed working (previous owner has cable off behind cluster) I noticed the speedo seemed to read faster than my seat-of-the-pants velocity meter... so I then compared the ODO mileage against mile markers on the expressway, yeah it reads too fast as well.
Is there any gearing in the speedo head or does the cable drive it directly?
Reply #3February 01, 2015, 04:25:31 am
« Reply #3 on: February 01, 2015, 04:25:31 am »
Any chance you have the gasser AGB? That box runs the engine/speedo 15% faster.
http://www.brokevw.com/020ratios.html
You could put in a green gear and get closer, and/or tweak the speedo by moving the needle on its shaft. Odo would still be off.
I'm wondering if the cluster is original, or from elsewhere.
Reply #4February 01, 2015, 07:36:34 am
30dodgeboy
  • 12
« Reply #4 on: February 01, 2015, 07:36:34 am »
I confirmed that AGS is stamped on the trans.  Wrong trans would be way too easy right??? :)  The AGB would make the engine spin slower / drive further for a same RPM and make the speedo read slow anyways.  Now the ECO AVX trans at 4.25:1 could cause this, but again the trans is clearly stamped AGS.  Could the final drive gears have been swapped in the case saw at some rebuild previously?  I have no tach to record RPM and compare calculated / actual MPH.
Cluster appears to be original, with about 182K on it.  Has part numbers 191 919035BJ and 191 919059A and (a date code?) of 008/ 298/19 on it.  Not sure how to read it if its a date code.
I did just recently try the green gear - it is a little more accurate but still reads too fast.
I really don't want to move the needle as then the speedo will only be correct at a certain MPH.  And as you said the odo will still be off.
Thanks for the help.  Any other ideas???
Reply #5February 01, 2015, 08:36:18 am
Dakotakid
  • 1240
« Reply #5 on: February 01, 2015, 08:36:18 am »
Purchase and install a different diesel cluster.
Reply #6February 01, 2015, 08:57:37 am
30dodgeboy
  • 12
« Reply #6 on: February 01, 2015, 08:57:37 am »
Do you know where I can find one (reasonably priced)?
I have a 1.8 8V cluster from a 1991.  Would the speedo head be the same?  I suppose I could just install the entire cluster to test the speedo accuracy without hooking up the electrical...  just thinking out loud now.  Maybe once this blizzard is over.
Reply #7February 01, 2015, 09:06:50 am
« Reply #7 on: February 01, 2015, 09:06:50 am »
I would first verify the total drive ratio... Put the car in 5th and push it back one tire revolution, counting the times the crank pulley turns.
Reply #8February 01, 2015, 09:20:53 am
30dodgeboy
  • 12
« Reply #8 on: February 01, 2015, 09:20:53 am »
Good idea.
Reply #9February 02, 2015, 08:49:18 am
« Reply #9 on: February 02, 2015, 08:49:18 am »
Hey, doesn't the speedo drive off the final output side of the diff?  Meaning that the ratios in the transmission are meaningless?
Reply #10February 02, 2015, 10:28:55 am
30dodgeboy
  • 12
« Reply #10 on: February 02, 2015, 10:28:55 am »
Speedo is driven off the pinion, so final drive ratio is a factor.
Reply #11February 12, 2015, 04:09:07 pm
30dodgeboy
  • 12
« Reply #11 on: February 12, 2015, 04:09:07 pm »
I confirmed the final drive is 3.94:1  I marked a tire and the crank pulley.  Put the trans in 5th and pushed the car exactly one tire revolution while counting crankshaft revolutions.  Divided the count by .75 for 5th gear ratio and my calculator said 3.9:1 ...
Odometer seems like it may be close but speedo reads much too fast.
