Author Topic: FS:1.6 TD kit almost complete  (Read 4148 times)
January 31, 2015, 05:11:44 pm
OhhKhay
  • 1
« on: January 31, 2015, 05:11:44 pm »
$500 or obo.
 this kit comes with just about everything you need. The only piece that I am missing is the air box, however a cone filter will work just fine or you can modify a digi2 air box etc. What you are buying:
 1) T3 turbo - minor shaft play up and down, no in and out. The wastegate looks a little rusty but it is still holding firm. The nuts for the downpipe are kind of crusty. I would recommend replacing them.
 2) Downpipe. It's a MK2 style one and is very solid. I don't see any reason why you can't make this one work on a MK1
 3) turbo to manifold bolts and intake manifold bolts
 4) exhaust manifold
 5) complete intake manifold
 6) CCV hose
 7) Intake hose
 8) Boost hose
 9) oil feed line
 10) oil return line (very hard to find)
 11) oil pan
 12) oil filter flange stand
 13) oil cooler with hoses and metal coolant line.
 14) MK2 rear motor mount (apparently they are different) - not pictured
 15) Oil pump. I'm assuming that this is a 36mm oil pump found on the later engines. I have not taken it apart to verify that or check it's condition
 Pm for best response.
[/URL]
[/URL]
Reply #1January 31, 2015, 06:31:21 pm
Re: FS:1.6 TD kit almost complete
« Reply #1 on: January 31, 2015, 06:31:21 pm »
Might not mean anything but this is a copy and paste almost exactly of my post from 2011. I'm raising a yellow caution flag until we hear a bit more from the seller.
http://www.vwdiesel.net/forum/index.php/topic,28612.msg241173/topicseen.html#msg241173
Also the exhaust manifold pictured is from a na, not td
« Last Edit: January 31, 2015, 06:35:09 pm by burn_your_money »
