Author Topic: Replaced oil cooler seal  (Read 6796 times)
January 31, 2015, 03:49:09 pm
92EcoDiesel Jetta
« on: January 31, 2015, 03:49:09 pm »
I've been getting oil drips down the oil filter and suspect it's the oil cooler o-ring. Got one from the dealer p/n 038 117 070A for a little over $5. When I read that the 27 mm nut is very thin I grounded my 27 mm deep socket's face flat to not have any problems. It was not on very tight! The nut is less than 1/8" thick! Why did VW decide to use such a thin nut?
With both coolant hoses attached, I could not get the cooler off the center stud. I undid the upper hose- a PITA and still had a hard time- it was hitting the bottom hose at the block. I was about to undo the lower hose but tried rotating the oil cooler a few degrees first and that allowed it to clear the center stud and drop down.
Got everything back together and started the car and no oil gushed out but have not driven it yet. Time will tell if the job was successful.
« Last Edit: January 31, 2015, 03:51:30 pm by 92EcoDiesel Jetta »
Reply #1January 31, 2015, 04:48:15 pm
Re: Replaced oil cooler seal
« Reply #1 on: January 31, 2015, 04:48:15 pm »
Maybe to not interfere with the top of the filter?
Reply #2January 31, 2015, 05:10:27 pm
92EcoDiesel Jetta
« Reply #2 on: January 31, 2015, 05:10:27 pm »
Nope, the nut runs deep into the cooler, about 3/4 to 1"
Reply #3January 31, 2015, 05:15:13 pm
air-cooled or diesel
« Reply #3 on: January 31, 2015, 05:15:13 pm »
about the squeeze you put on filter gasket, space for tighten to seal compression(o-ring)
Reply #4January 31, 2015, 05:16:52 pm
92EcoDiesel Jetta
« Reply #4 on: January 31, 2015, 05:16:52 pm »
Huh?
Reply #5January 31, 2015, 05:36:25 pm
92EcoDiesel Jetta
« Reply #5 on: January 31, 2015, 05:36:25 pm »
The center tube (I erroneously called it a stud) has about 2" of threads and the nut is way up there,  no where near the filter gasket.
Reply #6January 31, 2015, 05:39:54 pm
« Reply #6 on: January 31, 2015, 05:39:54 pm »
Top of filter is close to nut...
Reply #7January 31, 2015, 05:45:56 pm
92EcoDiesel Jetta
« Reply #7 on: January 31, 2015, 05:45:56 pm »
Yeah you're right. I could't see and the deep socket feels like it's way up in the cooler while tightening the nut.
Reply #8January 31, 2015, 06:20:34 pm
« Reply #8 on: January 31, 2015, 06:20:34 pm »
That nut is rarely on very tight. Channel locks or vise grips work great. Once you get the nut off, slide the cooler down and then use vise grips to loosen the oil tube. It doesn't matter if you damage the threads a bit, they are all covered by the oil cooler and are not needed.
As an aside, it's really a heat exchanger since it also heats the oil on cold starts.
Reply #9January 31, 2015, 07:20:23 pm
92EcoDiesel Jetta
« Reply #9 on: January 31, 2015, 07:20:23 pm »
"Nut is rarely on very tight"  Is that good or bad or normal? I think mine was too loose and was cause of the drip. Good tip with the vise grips. Would have saved me from undoing the coolant hose if I knew. It was 4 pm 25 F sun was still up so not too cold when I started. I was worried I'd get stuck not able to finish before sun goes down but lucked out and was done in about 1 hour. I started the engine idled it for 10 minutes to warm up the filter/ cooler a little before work and that really helped to not have frozen fingers.
Reply #10January 31, 2015, 07:27:05 pm
« Reply #10 on: January 31, 2015, 07:27:05 pm »
Maybe as much torque as a filter should be fine.
The seals do get brittle and crack.
Reply #11January 31, 2015, 07:39:31 pm
92EcoDiesel Jetta
« Reply #11 on: January 31, 2015, 07:39:31 pm »
Mine was not cracked, just flattened and looked like crap. I'll take pic of it and post later.
Reply #12January 31, 2015, 09:58:23 pm
« Reply #12 on: January 31, 2015, 09:58:23 pm »
I don't have my Bentley with me but someone should post the official torque spec. Good tip on warming the coolant a little before starting this job.
Reply #13February 01, 2015, 04:03:13 am
« Reply #13 on: February 01, 2015, 04:03:13 am »
18 ft-lbs.
Reply #14February 01, 2015, 08:23:22 am
« Reply #14 on: February 01, 2015, 08:23:22 am »
18 ft-lbs.
Thanks.
