Author Topic: Engine mount question  (Read 2307 times)
January 20, 2015, 10:33:47 pm
phaetonv10
  • 83
« on: January 20, 2015, 10:33:47 pm »
Hello people.
Is this engine mount an upgrade for the 1.6td or a Downgrade???
I installed this and my car started vibrating like an earthquake.
Should I change back to stock??
THE LEMON
1.6 GTD, FMIC, ARP Studs, Brembo brakes, Power Clutch, ibiza tdi twin fan setup, Racing Seats, 40 mm all aluminium radiator, audiophile music.
Reply #1January 21, 2015, 01:17:48 am
Re: Engine mount question
« Reply #1 on: January 21, 2015, 01:17:48 am »
Did you notice a change in the pitch of the engine angle?
Those mounts don't seem to compress from engine weight as much as stock mounts. So, other parts with small clearances may make contact with the chassis.
Reply #2January 22, 2015, 09:05:19 am
phaetonv10
  • 83
« Reply #2 on: January 22, 2015, 09:05:19 am »
Yea. The engine seemed to be a little tilted. But all seems clear. Nothing in contact with the chassis.
But I feel engine vibrations are significantly higher inside the cabin.
THE LEMON
Reply #3January 22, 2015, 09:49:25 am
« Reply #3 on: January 22, 2015, 09:49:25 am »
I've been running a right hydro in my 86 Jetta for about a month, to see if the mount will compress over time. (Not much yet. ) My engine seems to be an inch higher on the right, but my stock mount was shot, so it's kinda hard to say the real height difference, unless I put a new stock mount in to compare.
I think the vibration is reduced in my case; but like I said, the previous mount was toast.
