Author Topic: Are 1.5 non a/c brackets and 1.6 the same?  (Read 2017 times)
January 18, 2015, 03:13:38 pm
jlpst94
  • 72
« on: January 18, 2015, 03:13:38 pm »
Anyone know if the 1.5 brackets will work on a 1.6 block ?
Reply #1January 19, 2015, 12:09:55 pm
  • 2931
Re: Are 1.5 non a/c brackets and 1.6 the same?
« Reply #1 on: January 19, 2015, 12:09:55 pm »
 No.
 The problem is the upper timing belt cover support bolt is in a different location.
 It also won't bolt to the injection pump bracket because of different placement of the holes,..
 but you might be able to drill and tap a new hole in the injection pump bracket to match it.
 The stamped steel 1.5 bracket is also known to crack near the adjuster support.
Reply #2January 20, 2015, 03:47:28 am
jlpst94
  • 72
« Reply #2 on: January 20, 2015, 03:47:28 am »
Thanks, I'll keep shopping for a 1.6 bracket
