Author Topic: 92 jetta 1.6 na overheating  (Read 9667 times)
Reply #15January 19, 2015, 05:05:04 pm
air-cooled or diesel
Re: 92 jetta 1.6 na overheating
« Reply #15 on: January 19, 2015, 05:05:04 pm »
you need vw coolant, correct one
Reply #16January 19, 2015, 07:08:34 pm
nissannx
  • 75
« Reply #16 on: January 19, 2015, 07:08:34 pm »
Is the restrictor necessary? Can I just cut it out?
Reply #17January 19, 2015, 07:15:55 pm
« Reply #17 on: January 19, 2015, 07:15:55 pm »
System will still work without the restrictor, it is really to bleed air. But when it plugs, air won't purge and the system can overheat.
When the restrictor is removed, slightly more coolant is diverted away from the radiator to the tank. No biggie.
You can use any coolant in a 1.6.
Reply #18January 24, 2015, 02:06:29 pm
nissannx
  • 75
« Reply #18 on: January 24, 2015, 02:06:29 pm »
I just tackled this over heating problem. My restrictor was completely plugged. Had to drill it out. Also added straight water and rad flush and took it for a test drive. Engine was running at 195 and 200 if I stomped on it. Never over heated and the whole rad is warm again. Going to test the old thermostat tonight. Just waiting for the car to cool down to fill with proper coolant
Reply #19January 24, 2015, 02:23:06 pm
« Reply #19 on: January 24, 2015, 02:23:06 pm »
i dont happen to agree; that doesnt mean it will be a problem; vw coolant runs $28 or so.
Reply #20January 24, 2015, 02:27:30 pm
« Reply #20 on: January 24, 2015, 02:27:30 pm »
i run straight water thru 2X after flush, (fully warming up both times). after a flush you now are safe to use red vw coolant(if you already havent used).
Reply #21January 24, 2015, 03:43:46 pm
« Reply #21 on: January 24, 2015, 03:43:46 pm »
So, a t-stat change and restrictor fix. Not too painful.
(WP change can be a project.)
Refill with coolant of choice, but don't mix the spendy stuff with cheap. Bad mojo.
Reply #22January 24, 2015, 04:05:39 pm
nissannx
  • 75
« Reply #22 on: January 24, 2015, 04:05:39 pm »
Water pump still looks good. Has gold thick fins. Took it out for another test drive and so far so good.
Real test will be Monday.
Reply #23January 24, 2015, 04:42:08 pm
« Reply #23 on: January 24, 2015, 04:42:08 pm »
dont use the cheap-o .
so after clearing you dont have much residue in the flush/mix?
replacing wp means timing work
« Last Edit: January 24, 2015, 05:23:57 pm by air-cooled or diesel »
Reply #24January 24, 2015, 06:38:28 pm
nissannx
  • 75
« Reply #24 on: January 24, 2015, 06:38:28 pm »
The old thermostat tested fine so it looks like it was the restrictor. When I flushed the system a lot of scale came out
Reply #25January 24, 2015, 06:47:28 pm
« Reply #25 on: January 24, 2015, 06:47:28 pm »
perhaps flush again; you can drive it like 50 miles max and of course drop (water) when warm
just dont drive so far away if something does happen
Reply #26January 24, 2015, 07:29:11 pm
nissannx
  • 75
« Reply #26 on: January 24, 2015, 07:29:11 pm »
I have already added coolant. I will find more out Monday when I drive it to work
Reply #27January 25, 2015, 05:10:13 am
Gizmoman
  • 1301
« Reply #27 on: January 25, 2015, 05:10:13 am »
Sounds like you have it solved. One thing that wasn't mentioned - you may want to either have the radiator rebuilt or replaced. Don't know how old your vehicle is but over time they fill up with crud and loose efficiency. The "lot of scale" is a clue to a plugged radiator.
Reply #28January 25, 2015, 06:06:32 am
nissannx
  • 75
« Reply #28 on: January 25, 2015, 06:06:32 am »
I'm planning on swapping the 1.6td this summer. I'll make sure it gets a new rad at that time
Reply #29January 27, 2015, 12:48:00 pm
  • 2931
« Reply #29 on: January 27, 2015, 12:48:00 pm »
It wasn't moving then in 5 minutes just started coming out the reservoir.
That didn't answer my question.
Could still be just a clogged line.
