Author Topic: Nice cloud of smoke and rough start on 1.6 IDI engine  (Read 3429 times)
January 15, 2015, 05:55:22 am
srgtlord
  • 797
« on: January 15, 2015, 05:55:22 am »
So over the past month or so my MK2 golf 1.6 IDI has been experiencing issues upon start up where it feels like the engine is skipping for a few minutes and there is a nice blanket of bluish smoke and then suddenly the cars runs normally.  Originally I thought it was a fuel filter issue but I noticed that cycling the glow plugs multiple times seems to eliminate most of this rough cold start issue. My thought is it might be an injector or 2 with a bad spray pattern.  Any advice is greatly appreciated.
Reply #1January 15, 2015, 07:47:55 am
Jetmugg
  • 530
Re: Nice cloud of smoke and rough start on 1.6 IDI engine
« Reply #1 on: January 15, 2015, 07:47:55 am »
Have you verified that all 4 glow plugs are working correctly?
Steve.
Reply #2January 15, 2015, 08:29:13 am
srgtlord
  • 797
« Reply #2 on: January 15, 2015, 08:29:13 am »
Not yet. The bosch duraterm plugs that are in the motor now only have about 1 year's use on them but anything is possible. What is the best way to test the glow plugs? Jumper cables and a spare battery?
Reply #3January 15, 2015, 10:13:35 pm
« Reply #3 on: January 15, 2015, 10:13:35 pm »
Best way I found was to pull all the injectors and cycle the key.  Do it at night and you should see a very red glow in each hole.  The other method is to pull each GP one at a time, and that to me takes more time and effort than four injectors.  I have extra heat shields so I have those pre bent to go in the holes once I am done checking and then just make sure I reform the shields prior to packing them away.
Reply #4January 16, 2015, 09:18:15 am
« Reply #4 on: January 16, 2015, 09:18:15 am »
You also can just cycle the GPs then touch the end of them; if they are working they'll be warm, if not then nope.  And yes, I mean the threaded end with the bus bar attached.  Don't touch the other end... :-/
Reply #5January 16, 2015, 10:23:57 am
Derekxj
  • 74
« Reply #5 on: January 16, 2015, 10:23:57 am »
What do you mean by pre-bent and " reforming " the shields?  When you install new heat shields under the injectors you need to bend them???
Reply #6January 16, 2015, 03:33:32 pm
EcoTX
  • 113
« Reply #6 on: January 16, 2015, 03:33:32 pm »
He means he reforms the old ones instead of putting new ones in.
If you use new ones, you do not need to do anything to them.
Reply #7January 16, 2015, 06:54:17 pm
« Reply #7 on: January 16, 2015, 06:54:17 pm »
That is right, I have like 15 of them around here from various heads,  I use a small steel ball and vicegrips along with the spacer from my compression tester kit.  Have not had a problem with reforming them for years.  But do buy some new ones so you have the spares at hand if you are just getting into the diesel business.
Reply #8January 19, 2015, 02:23:04 pm
air-cooled or diesel
« Reply #8 on: January 19, 2015, 02:23:04 pm »
you need to be careful when you jump glow plugs; what i mean is Dont jump directly at battery; batteries can explode; then you get battery acid all over you as well,,
