Author Topic: EGT Probe and Gauge from different manufacturers?  (Read 6585 times)
December 30, 2014, 04:52:55 am
DRP67207
  • 50
« on: December 30, 2014, 04:52:55 am »
Hello all, my apologies if this has been covered before, i couldn't find anything searching on here or on the broader interweb.
I am looking to get an EGT setup for the mTDI swap I'm working on.  I've found many recommendations for the Micro-1000 EGT probes offered by Aircraft Spruce, specifically EP132 EGT Probe (1/8 NPT).  However, I'd prefer to use a VDO gauge rather than the Westach one people recommend in conjunction with that probe.  These are both "K type", but will the combination of a Micro-1000 probe and VDO EGT gauge be compatible and give accurate readings? Is the accuracy and responsiveness of the gauge primarily a function of the probe or the gauge?  If anyone has any experience with or insight into this specific setup, please let me know.  Thank you for your assistance.
Reply #1December 30, 2014, 01:17:01 pm
Re: EGT Probe and Gauge from different manufacturers?
« Reply #1 on: December 30, 2014, 01:17:01 pm »
If it is K type it will work with any K type. The gauge and probe both have to be accurate and the VDO will probably be fine.
Reply #2December 31, 2014, 04:48:04 am
DRP67207
  • 50
« Reply #2 on: December 31, 2014, 04:48:04 am »
Thanks for the reply.  Anybody running a VDO EGT gauge and able to vouch for its accuracy/responsiveness?  I believe that I've heard elsewhere that they aren't quite as responsive as the Westach versions, but they do match the other gauges...
Reply #3January 01, 2015, 03:24:12 pm
ToddA1
  • 434
« Reply #3 on: January 01, 2015, 03:24:12 pm »
I'm running the micro probe and the VDO Vision gauge. It works fine. Very fast.
-Todd
Reply #4January 02, 2015, 05:13:23 am
DRP67207
  • 50
« Reply #4 on: January 02, 2015, 05:13:23 am »
Great, that's what I wanted to hear.  Sounds like that's what I'll go with then.  Thanks!
