Model Specific Questions and Info
MK1 Golf/Jetta and B1 Dasher
1.6td Clutch
Topic: 1.6td Clutch (Read 5255 times)
December 08, 2014, 06:58:42 am
homerj1
1.6td Clutch
December 08, 2014, 06:58:42 am »
Finally will be putting a 5speed (ff code) from a mk1) into my 84 Jetta with a 1.6td & wanted to confirm my clutch options.
1. Buying a new 200mm clutch & pp & use my used 1.6td flywheel.
2. Buying a new 210 mm clutch & using my used aaz flywheel & pp
3. Any other options?
I would like to keep it simple and reliable & sort of affordable on the pocket book.
And what do I need to look for physically on the parts if I use a "used" pp and flywheel?
was thinking
http://www.autopartswarehouse.com/sku/Volkswagen/Jetta/Luk/Clutch_Kit/1984/Base/4_Cyl_1-dot-6L/LUK17004.html?tlc=Engine+%26+Drivetrain
Last Edit: December 08, 2014, 07:23:19 am by homerj1
December 08, 2014, 10:09:38 pm
flying_oliver
Newbie
Re: 1.6td Clutch
December 08, 2014, 10:09:38 pm »
The 210mm is strange because during the mk3 era they changed the PP and flywheel a little. It's described in the mk3 Bentley. Basically just keep the PP and flywheel for the same car year. Just keep an eye open for that.
December 09, 2014, 04:24:01 am
Re: 1.6td Clutch
December 09, 2014, 04:24:01 am »
There are single pin and dual pin flywheels, I ran into that.
Round 2
December 09, 2014, 10:08:17 am
Re: 1.6td Clutch
December 09, 2014, 10:08:17 am »
thats a great price on that clutch kit, another 50 bucks to get the fly wheel resufaced and you're good to go.
1.6td Clutch
