Author Topic: Toe-in  (Read 4315 times)
November 17, 2014, 07:38:07 am
92EcoDiesel Jetta
Toe-in
« on: November 17, 2014, 07:38:07 am »
Anyone know what the toe-in specs in inches are (not degree/minutes) for 92 Jetta and 81 Caddy? Most non VW cars I've owned in the past are 1/16". The Caddy manual I have says to set the toe-in as close to zero as possible...the closer to zero, the more squirelly the front end will feel. What do you set yours to?
Yes, I am doing it myself. Have been for many years with a pretty accurate method I've been using.
Reply #1November 17, 2014, 01:03:33 pm
Re: Toe-in
« Reply #1 on: November 17, 2014, 01:03:33 pm »
Why on earth would you use anything else?
Measuring from the tire? rim? what size rim?
I usually shoot for a convergence a little under an inch in 20 feet unless I need better turn in.
« Last Edit: December 23, 2014, 01:18:42 pm by burn_your_money »
Reply #2December 22, 2014, 02:27:33 pm
92EcoDiesel Jetta
Re: Toe-in
« Reply #2 on: December 22, 2014, 02:27:33 pm »
[image]http://mathworld.wolfram.com/images/eps-gif/IsoscelesTriangle_800.gif[/img]
Because a ruler cannot measure angles. What is that link you posted? Could not get it to work.
Reply #3December 23, 2014, 01:19:07 pm
Re: Toe-in
« Reply #3 on: December 23, 2014, 01:19:07 pm »
I fixed the link.
