TDI - VE Pump TDI Engines
ALH TDI ticking noise
Topic: ALH TDI ticking noise (Read 10488 times)
October 29, 2014, 10:56:27 am
3benny3
October 29, 2014, 10:56:27 am »
Got an 01 vw jetta that has been making this ticking noise for a pretty good while. It has 300k and is a manual with good and equal compression on all cylinders. Just did timing belt etc and put in new cam followers and recently new injectors. Ticked before and still ticks now, any ideas? www youtube com/watch?v=fVQ1kJf8YNg&app=desktop (replace spaces with periods)
Thanks, Ben
October 29, 2014, 05:13:19 pm
Re: ALH TDI ticking noise
October 29, 2014, 05:13:19 pm »
That sounds terrible. My best guesses would be piston/valve contact or a broken piston.
November 15, 2014, 05:20:11 pm
Blocksmith
Wrench Lurker
November 15, 2014, 05:20:11 pm »
One thing I've always been concerned with when people post videos of engines running is just how true is the sound quality; so many people post videos from smartphones now, and the microphones on all of them are mediocre at best if you're after quality sound reproduction. An application like this, diagnosing an engine noise, would benefit from the highest quality microphone one could reasonably use--anything less might lead to misdiagnosis.
You mentioned that the compression was equal on all cylinders; just out of curiosity what were the actual numbers?
How well does it start and respond to throttle? Is there smoke?
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
November 15, 2014, 06:02:50 pm
November 15, 2014, 06:02:50 pm »
Did you watch the video? The sound quality isn't great. You can definitely hear compression on it, but that doesn't matter. The noise is unmistakable. I would say that it is lifters, injectors, piston/valve contact or a bad piston. He says the lifters and injectors were already replaced with no change.
November 16, 2014, 06:43:04 am
November 16, 2014, 06:43:04 am »
Is there a reason you put spaces on the video instead of linking directly?
To me it sounds like an intake or exhaust leak near the head.
Did you use quality parts or did they come from North Carolina?
December 18, 2014, 10:13:29 pm
derf_kcire.XXII
Newbie
December 18, 2014, 10:13:29 pm »
Does the noise gets more audible when filler cap is screwed off? Then it's from the top probably.
December 24, 2014, 09:34:28 pm
srgtlord
December 24, 2014, 09:34:28 pm »
for giggles I would do an oil pressure check....
February 19, 2015, 03:10:36 am
smutts
ClackClackClackClackClack
February 19, 2015, 03:10:36 am »
Did you find out what was causing it?
