Author Topic: Kerosene or Jet A???  (Read 5303 times)
October 26, 2014, 11:53:56 am
ftm1776
  • 149
« on: October 26, 2014, 11:53:56 am »
Can the VW diesel engine burn common kerosene or Jet A turbine fuel (also a form of kerosene for jet engines)????
Comments??
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1October 26, 2014, 12:07:08 pm
Re: Kerosene or Jet A???
« Reply #1 on: October 26, 2014, 12:07:08 pm »
If you look around a bit you should find that these fuels are lighter than #2 diesel and in some instances it is recommended to blend some into your fuel if you have gelling problems in the cold.  They are not as good with lubrication so some extra oil, 2 stroke or other diesel additive would be good to throw in there as well.  They are not intended to run as a 100% replacement to #2 Diesel.  And since there isn't a road tax on them there might be some frownage by anyone dipping the tank.
Kerosene is a good cleaner and some recommend a bit to the tank if you are having issues with the injectors.  But then so is adding Auto Trans fluid or some other diesel based injector cleaner.
As with all alternative fuels it is always better to blend than run straight.  Even those running waste motor oil find it can run on it at 100% but runs better with something like a 70/ 30 mix of something more fuelish not foolish in nature.
Reply #2October 30, 2014, 12:02:30 pm
3benny3
« Reply #2 on: October 30, 2014, 12:02:30 pm »
 I run jet a in my little 1.6 td fairly regularly, usually add 2 stroke oil though. Running 100% will make the exhaust smell slightly different, but not as noticeable as running b100. No noticeable difference in power or e's's.
Reply #3October 31, 2014, 09:17:10 am
wolf_walker
  • 1205
« Reply #3 on: October 31, 2014, 09:17:10 am »
We used to use the takeoff jeta in a couple of vw-d's, few gallons here and there, no problems.
No idea what the cetane is on that stuff.
Mentat Text Two
Reply #4November 01, 2014, 09:10:13 am
  • 1739
« Reply #4 on: November 01, 2014, 09:10:13 am »
"runs better with something like a 70/ 30 mix of something more fuelish not foolish in nature."
ha, good one!
Reply #5November 02, 2014, 07:08:02 pm
commuter boy
  • 277
« Reply #5 on: November 02, 2014, 07:08:02 pm »
I've used Jet A once when I got stuck in a small town in Alaska after all the gas stations closed for the weekend.   I wouldn't recommend it for long term use, it doesn't have the lubricity of regular diesel.
Reply #6November 07, 2014, 07:13:12 pm
Rising
  • 385
« Reply #6 on: November 07, 2014, 07:13:12 pm »
When I ran it a few times I always added some atf for lubricity... Also I noticed my car went from rolling coal to being as clean burning as a Prius. Visible exhaust smoke in my experience is nil. That's actually why they made jet-a to my knowledge. Reducing jet trails in the sky to make air travel seem more appealing. Or some such thing I heard working at an aviation shop.
'84 Rabbit Diesel- 1.6D Stock
