IP prime / bottle feed procedures
Pages:
Topic: IP prime / bottle feed procedures (Read 5405 times)
Reply #15
November 08, 2014, 05:37:08 pm
Moderator
4552
Re: IP prime / bottle feed procedures
Reply #15 on:
November 08, 2014, 05:37:08 pm »
Only thing I would try that you are not is to be sure the cold start lever is Out all the way and give it half throttle when cranking. You sure all the fuses are good, each GP is getting 12VDC? Not just the block that breaks them to individual lines?
These are the types of problems that give one gray hairs.
Reply #16
November 08, 2014, 09:10:17 pm
TimpanogosSlim
Pretty dumb for a smart guy
Reply #16 on:
November 08, 2014, 09:10:17 pm »
You can clear any air from the leak lines by removing the cap from the end and pinching off the return line while the lift pump does it's thing. Wait until you have a clear flow of diesel from the last injector.
Reply #17
November 09, 2014, 06:25:29 am
Jetmugg
Reply #17 on:
November 09, 2014, 06:25:29 am »
If you have the possibility of tow-starting it, give it a go. Level ground, a good helper, and a good strap should get the job done.
Reply #18
November 09, 2014, 08:41:43 am
Reply #18 on:
November 09, 2014, 08:41:43 am »
A tow shouldn't be necessary in my opinion, especially if this is a fresh rebuild.
My first thought would be timing.
Pages:
