VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Troubleshooting
headgasket whoes
Topic: headgasket whoes (Read 4013 times)
March 25, 2006, 10:57:42 am
91turboeco
headgasket whoes
March 25, 2006, 10:57:42 am »
it took a while but i final got the headgasket on and finshed. the first time i started it i couldn't get it with the starter so i draged it. when it finally started it was running rough, i could not let off or it would stall, there was no power. i was thinking that maybe it would have to break it or something''first headgasket on a diesel.'' after it warmed up i turn the bolt the other quarter turn when to start it wont start had to drag again.
well today i go out to work on it see whats going on. i turn the motor by hand and hear compression escaping from i thing the valves. from all 4 cylinders. im guessing that its not normal. wonder what i shound do?
do the gasket again,reseat or replace valves??
March 25, 2006, 11:06:32 am
bryanbryan89x
headgasket whoes
March 25, 2006, 11:06:32 am »
Im curious, how come you did not go with the metal 1.9 head gasket?
1981, Rabbit Car, 1.6, N.A.
March 25, 2006, 02:09:06 pm
91turboeco
headgasket whoes
March 25, 2006, 02:09:06 pm »
the place a got it had the 1.6 in stock and it would of took a week the get the 1.9.
how you know i had the 1.6??
March 26, 2006, 08:22:35 pm
bryanbryan89x
headgasket whoes
March 26, 2006, 08:22:35 pm »
Well aslong as you have the timing correct, and it did not have these symptoms before you changed the head gasket. Maybe the head is warped, or improper torque sequence??
March 26, 2006, 08:28:25 pm
bryanbryan89x
headgasket whoes
March 26, 2006, 08:28:25 pm »
March 27, 2006, 07:06:05 am
91turboeco
headgasket whoes
March 27, 2006, 07:06:05 am »
torque i know it right. check head with straight edge seemed fine to me. if the heads warped it woundnt be coming from the valves would it??
General Information
Troubleshooting
headgasket whoes
