Author Topic: coolant hoses  (Read 2956 times)
September 16, 2014, 02:25:33 pm
ropadopa
  • 58
coolant hoses
« on: September 16, 2014, 02:25:33 pm »
Looking to buy a coolant hose kit or the best way to go about it . 1992 1.6 with ac
1992 ecodiesel
Reply #1September 16, 2014, 07:47:01 pm
ropadopa
  • 58
Re: coolant hoses
« Reply #1 on: September 16, 2014, 07:47:01 pm »
wasnt there a person on here that deals with silicone hoses ?
1992 ecodiesel
Reply #2September 16, 2014, 09:16:20 pm
Re: coolant hoses
« Reply #2 on: September 16, 2014, 09:16:20 pm »
Yeah, there sold through mk1autohaus (on ebay) though, and it's actually someone else selling them (but I've always had good experiences with that seller).
I don't use their radiator hoses though, just the regular Meyle ones, they seem to last a long time even if they are made in China now or wherever. On azautohaus.com and gowestyautoparts.com you can get them for pretty cheap.
Reply #3September 16, 2014, 09:35:50 pm
sdubfid
  • 63
Re: coolant hoses
« Reply #3 on: September 16, 2014, 09:35:50 pm »
user gee bee on here
Reply #4September 17, 2014, 01:02:34 pm
thegimpster
  • 243
    • VDubShirts.com Awesome VW themed shirts with attitude
Re: coolant hoses
« Reply #4 on: September 17, 2014, 01:02:34 pm »
I can get new oem ones fairly cheaply.
Check out www.vdubshirts.com for cool VW themed shirts with attitude.
Reply #5September 17, 2014, 01:17:09 pm
ropadopa
  • 58
Re: coolant hoses
« Reply #5 on: September 17, 2014, 01:17:09 pm »
thanks allot again guys . i have a tiny leak for the past year and it behind the oil cooler, My bet is the metal tube, any chances that the oil cooler itself could leak?
I dont want to disturb anything down there unless i have ammo, (new hoses/pipe)
Thanks for the sites they look to have everything i need except some of the listings are screwy.  I need the 3 leged molded hose that says auto trans when my ECO is manual  Im guessing its an eco thing listing error ,
any more input is always awesome.
1992 ecodiesel
Reply #6September 17, 2014, 09:47:40 pm
Re: coolant hoses
« Reply #6 on: September 17, 2014, 09:47:40 pm »
Yes there's a good chance the oil cooler can leak, it can leak from the pipes or internally (then you get a coolant/oil mixing situation).
Reply #7September 17, 2014, 10:05:26 pm
RustyCaddy
  • 395
Re: coolant hoses
« Reply #7 on: September 17, 2014, 10:05:26 pm »
That seems to be the correct hose for the manual as well, a least that is what is in the pickup.  Part number 068121053P.  The new Meyle version isn't all rubber, it has a plastic "T".  Be interesting to see how it holds up (or possibly very inconvenient if it turns out to be less reliable).  Rothenbacher sold a thin all rubber version but it is out of stock. Found an all rubber version available on ebay-Germany...if you can read German to order it  ;)
VW is also out there but pricey.
Turns out his piece isn't being made in silicon.
« Last Edit: September 17, 2014, 10:10:16 pm by RustyCaddy »
Reply #8September 19, 2014, 06:10:55 pm
GEE-BEE
  • 1604
Re: coolant hoses
« Reply #8 on: September 19, 2014, 06:10:55 pm »
Thats correct I do silicone hoses, made to order
aaz/ ahu
GB
Note: we mfg 3 ply silicone with no plastic joiner / T fitting
All one piece
http://www.thesamba.com/vw/classifieds/detail.php?id=1631999
http://www.thesamba.com/vw/classifieds/detail.php?id=1078372
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
