Well its been a few weeks, since the install. i thought i would share some results.
Before the downpipe the car boosted 5-6 psi of boost and you really had to ring it out to get 7-8 psi
After the pipe and removing restrictive semi clogged catalytic converter 260K miles.it goes 7-8 pretty quick and 10-11 at high RPM.
After that i did what any other Hot Rodder would do, i tightened the waste gate spring one turn without much change then turned the fuel screw tight one half turn and two more rotations on the waste gate.
Wow, car feels twice as fast, I mean i can keep up with traffic and drives like a normal car.
Boost goes straight to 10PSI evry gear and stays, until the Florida heat takes away a PSI or 2 , I would imagine a intercooler would solve that.
i tried turning the fuel screw 1/4 more of a turn and no more power but more smoke just wanted to try it to see if there was something i was missing.
I turned the fuel screw back to half turn in from stock and have been drivin it for 7-800 miles and MPG"S are closer to 40mpg when before i was closer to 45mpg.
I may move it back out a fuzz to see how it acts.
Did this with no EGT guage , just seat of the pants tunning. I know this isn't recommended but im only messing with 10PSI and i figured that since the ECO dosent have an LDA that if anything its gets leaner the higher the RPM so im hoping it wont be any trouble at this tune. Please feel free to correct my thinking.
