Fixmyvw.com
Author Topic: Oil Cooler Upgrades  (Read 13075 times)
August 21, 2014, 10:48:23 pm
  • Administrator
  • 2831
Oil Cooler Upgrades
« on: August 21, 2014, 10:48:23 pm »
I'm thinking I want to upgrade my oil cooler a bit...
When I'm on the I-5 I'm usually running along around 125 km/h or so.  When I've got a couple of bikes on the rack on a hot summer day I've been seeing oil temperatures around 115-117C at which point I start seeing the pressure drop off a bit - I'm measuring at the head which always reads low, but I'll see the pressure getting down as low as 1.3 bar at 2500 RPM.  Pull off and fuel up, the oil temps will be back to just over 100C and pressure will be more like 2.0 bar at 2500 RPM.
I really don't want to run an air cooler as I don't really want a bunch more oil lines to leak plus I've already got my AWIC taking up all the space in front of my radiator.  I've seen some folks with ALH engines run the larger Passat V6 coolers, but they don't have the filter on the bottom like the AHU and earlier engines do.  Has anyone upgraded to a larger oil/coolant heat exchanger?  Anyone know if the Passat V6 one will fit on an AHU / 1Z / AAZ / 1.6 without bumping the filter in to the front crossmember?
Reply #1August 22, 2014, 08:24:09 am
  • 7837
Re: Oil Cooler Upgrades
« Reply #1 on: August 22, 2014, 08:24:09 am »
I used an air to air and have no issues. Only been using it for 50,000 miles or so, but no leaks or issues of any kind. Maybe adding an extra quart at rebuild oil change, but you have an extra quart to heat up. I run right at 180-215f depending on the load and day. Never seen it go over 220f yet. Just giving you the perspective of something that works even if you don't want to use it.
Reply #2August 22, 2014, 09:10:31 am
« Reply #2 on: August 22, 2014, 09:10:31 am »
Well a bus oil filter off a 2.0 fits the housing... Its half as tall, but just as fat... Also... Proper v6 filter is too... Its short... We put diesel ones on though...
I agree on you oil temp... Once mine hits 100c it drops quiet fast... But same token, my coolent starts to spike up over 90c... And to keep pushing oil temp up raises coolent more...
So think about water temps... Add a 2nd sensor, a 2way toggle switch, use your oil temp gauge for both by flipping switch... See if you can load the cooling system down more first... I have 80c stats in my cars i see this on... The one with 72c stat a gasser, detonates by 100c
The water temp gauge will reflect the stat temp once up to temp... Normal load... You can see in the needle when it goes between open and closed... Ive found stock oil cooler to be abt 15c max then both increase the same...
« Last Edit: August 22, 2014, 09:18:07 am by CRSMP5 »
Reply #3August 22, 2014, 10:16:01 am
  • Administrator
  • 2831
« Reply #3 on: August 22, 2014, 10:16:01 am »
I haven't had any issues around high water temps - really if anything mine are somewhat low.  My water temps usually hang out around 80C unless I'm stuck in traffic not moving, but then it will only go high enough to turn on the fan.  My cruising EGTs are usually under 300C even at 125 km/h though so I'm not really making that much heat.  So I'm actually seeing quite a high delta between my oil temps and water temps - like 35C+ difference.  I really don't have much under-hood heat at all - big AWIC, free flowing exhaust, upgraded cam - this engine is breathing pretty well and keeping things cool on the top side.
Good idea on dual-purposing the oil temp gauge.  I have the aluminum head flange with the 3 coolant glowplugs in it on mine, I'm not using those GPs yet though.  I can install another temp probe in one of the GP holes pretty easily.  I am relying on my stock gauge right now which I believe to be fairly accurate but for the cost of a toggle switch and a sensor, might as well be double sure.
Did you keep the factory heat exchanger as well?  I'd imagine that would make for a pretty big stack between the filter housing and the filter, kind of the same problem as using the Passat heat exchanger...  If not then I'd need to cap off the hoses.  Yes, the extra quart of oil would definitely be a good thing - I'm not totally against the idea but there's something to be said for the factory setup in that it both aids heating up when cold while also keeping things cool on the top side.
Ideally I'm looking for oil temps right around 100C cruising.  If I'm in town and driving easy (keeping the RPMs low, not flooring the car constantly, etc) my oil temps are usually in the high 90C's which is fine.  It's just sustained high speed driving (or hauling my trailer) that causes them to get up there.
Reply #4August 22, 2014, 12:28:28 pm
« Reply #4 on: August 22, 2014, 12:28:28 pm »
Old non bubble block 1.6 with stock wp housings have perfect spot to tap n drill sensor.. So it reads lowest coolent point with stat open or close... Tdi housing and block lack room...
Bbobs i welded a nut to the metal coolent pipe...
I would not trust using gp hole... Unless sensor is far nuff in to flowpast the tip of sensor... It will not be accurate...
Been doing toggle switch idea for my whole driving life... Added it to my 1st car and all since... You must use a plain non light style switch... The bulb or led will make it not work right...
And yes its a tow or load issue at speed... Not normal condition issue.... But till you see the true #s you not seeing how it affects water
« Last Edit: August 22, 2014, 12:30:07 pm by CRSMP5 »
Reply #5August 22, 2014, 01:40:05 pm
  • Administrator
  • 2831
« Reply #5 on: August 22, 2014, 01:40:05 pm »
This is the sensor I would be using:
http://www.auberins.com/index.php?main_page=product_info&cPath=5_24&products_id=136
No problem getting that in to the real flow.  It is 1/8 NPT instead of M10 but that'll thread in to the M10 GP hole in the flange just fine.
CRSMP5, you were saying you see the same sort of pressure drop on your gasser engines - do you have any idea what sort of pressures you were seeing?  See I don't really see 125 km/h in 30C temperatures as being an abnormal condition - that's basically just summer highway driving.  Yeah I had a couple of bikes on the back, but other than wind resistance that's not really anything more than 1 adult or 2 children in the back seat weight wise.  Combined total weight including the rack shouldn't have been more than 130-150 lbs.  The trailer is definitely a different story.
My factory dynamic oil pressure warning system is still functional (in fact it saved my 1.6TD a number of years ago when the IM shaft seal failed rather suddenly - a big chunk broke off of it).  I believe the high pressure switch closes at 1.8 bar so my 1.3 bar reading at the head is likely artificially low as the alarm would be going off otherwise.
Reply #6August 22, 2014, 03:18:45 pm
« Reply #6 on: August 22, 2014, 03:18:45 pm »
Lowest you want to see.... 18psi at 2000 rpm.... What old 1.6td... Gassers were 22psi and na diesel... But turbo dropped op enough for 18psi...
Since newer tdi is on same design... And hydro heads got bigger oil pumps... 18psi is min...
During my crazy move using kubvan to flat tow crap cross hills and mountains... Ive been running 20-50 as i still have oil use issue... Turbo #2 pumps oil... Got #3 but keep resisting as if ive popped 2... Need to upgrade... But when i popped #2 i did lift the head and the wrx did not win :)
So due to first popped turbo ive had oil pressure issue... 20-50 solved pressure issue... And for my oil temp, vs water temp, vs oil pressure... Has good knowledge of first hand experiances
Reply #7August 22, 2014, 09:02:55 pm
GEE-BEE
  • 1604
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #8August 22, 2014, 10:37:35 pm
  • 7837
« Reply #8 on: August 22, 2014, 10:37:35 pm »
I didn't keep the stock cooler as I felt I didn't want to separate oil and coolant when it failed. You could make that a giant stack but I don't know if you would have room for it all.
Reply #9August 25, 2014, 09:53:19 am
« Reply #9 on: August 25, 2014, 09:53:19 am »
Some numbers... 500 mile load of crap trip... Kubvan, 98 tdi jetta 5 speed... 20w50 oil... 70-80f temps...
Gauges... Vdo... Sensors stock vdo kinds...
Start up... Tach = 4000 rpm which is 71.5 mph via gps in 5th gear... 195 50 15 kuhmos... You will have to math out true rpm...
120 psi and under 50c on oil and water
70 psi 70c water and under that on coolent
50 psi 80c and 80c
32ish psi 90c and 80c on water... Egt 800f
Where things get spooky...
25psi, 95c 85c on water.... Egt 800f....
22psi... 100c 90c egt 1000f....
Say pulling load up hill with wind...
But i know 100% that i have a bering issue due to oil starvation and oil foaming...
Reply #10August 25, 2014, 12:09:10 pm
rodpaslow
  • 670
« Reply #10 on: August 25, 2014, 12:09:10 pm »
I don't have a stock oil cooler, aftermarket aluminum using a GTI oil mount that fits perfectly to a 1.6tD and has the temp control unit inside it.  When I'm really on boost heavy it will climb to 250°F (oil temp); about 210 water temp, but still around 30 psi oil pressure, but over 1100°F egt for long periods with a VNT 17.
I would be concerned if it were below that - that's also synthetic oil.
22 psi might be regualar 20w50 oil? just curious.
Reply #11August 25, 2014, 06:34:34 pm
  • Administrator
  • 2831
« Reply #11 on: August 25, 2014, 06:34:34 pm »
50 psi 80c and 80c
Hmm your numbers are almost spot on mine actually in terms of the pressure / oil temperature.  Your coolant temperatures are higher but you're also pushing a box through the air.  I'm running Rotella T 15w40, you're running 20w50.
The interesting thing is that my oil temperatures are getting a lot higher than yours.  Now here's the possible contributory cause... I bought my oil cooler from ECS Tuning.  It does have 'GERMANY' stamped on it but the brand is something I haven't really heard of.  ALL of the rest of the parts I got from ECS that weren't a major brand component have been simply crap.  Wanna bet the oil cooler isn't worth squat either?
Reply #12August 25, 2014, 11:21:39 pm
  • 7837
« Reply #12 on: August 25, 2014, 11:21:39 pm »
I have a cheap cooler from summit with the thermostatic flap piece in it most say is junk. But I have a big 13"x7"x3/4" the 3/4" is the od of the tubes.
Reply #13August 26, 2014, 01:50:37 am
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« Reply #13 on: August 26, 2014, 01:50:37 am »
I've got the water-to-oil cooler that's stock on the 3.6-3.2L Touareg, Audi Q7, 3.2 Audi TT, etc:  VW 038117021B, rotated 90 degrees CCW to clear the block.  I modded the front engine mount to clear the stock heater hardpipe on my Mk1 Jetta.
The cooler is on a mostly stock 1.6TD that has the Garrett T3 replaced with a VNT-15 with manual linkage vane control (boost and throttle position).   Oil temps are now within 10 degrees F of water temps,  after warmup- no matter how hard its run, but a Mk1 Jetta is light.  The oil temp is measured at the pan drain and water temp at the back of the head (stock).   Oil filter change is a B#%^ for clearance with the core support...I need to try the 2.0L bus filter!!
Reply #14August 26, 2014, 11:17:14 am
  • Administrator
  • 2831
« Reply #14 on: August 26, 2014, 11:17:14 am »
Yeah you've got the 'big daddy' cooler...
I've been thinking of replacing mine with one of these:
Would be a bit of a tight fit.  P/N is 028 117 021E
S-PAutomotive.com
