Author Topic: belt tension  (Read 5382 times)
August 12, 2014, 02:46:53 pm
belt tension
« on: August 12, 2014, 02:46:53 pm »
Does this belt tension look ok? I thought "you should be able to twist the belt 90 degrees" and this looks like less.
It seemed tight to me, but I barely even moved the tensioner when I tightened it. With the other belts I've installed you had to move it maybe 1/4 turn but this was barely even 1/8 turn to get it to this point, it was maybe one finger's worth of a gentle pull. So I can't believe it would be too tight. This is also a different brand of belt than the Contitech I used before, it seems a lot more rigid and thick even without being tensioned than the Contitechs were. This was after 10 minutes of the engine being run, it was tighter before that.
« Last Edit: August 12, 2014, 02:48:28 pm by bajacalal »
Reply #1August 12, 2014, 03:35:06 pm
Blocksmith
  • 261
    Wrench Lurker
Re: belt tension
« Reply #1 on: August 12, 2014, 03:35:06 pm »
I believe the seat of the pants measurement for belt tightness is not 90*, but 45; it looks like you're about spot on from the video. I haven't put it on yet, but I also bought a Mitsuboshi belt, and I agree that it does seem to be made of slightly stiffer rubber than the Contitech belts.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #2August 12, 2014, 04:37:11 pm
Re: belt tension
« Reply #2 on: August 12, 2014, 04:37:11 pm »
That belt is tighter than I put them on. Bentley says to use gauge so I would defer to that. IM shaft and IP bushings like the looser side of things on the 45 to 90 twist scale.
Reply #3August 13, 2014, 08:15:31 am
Re: belt tension
« Reply #3 on: August 13, 2014, 08:15:31 am »
When I was still running my 1.6 I would go as loose as I could without belt flap between the pump and cam pulley.  The 'sweet spot' is very close to that "45 degree twist" - less tension and the belt will be flapping.  Once the belt is stable you should be good to go.  As was mentioned above, an overly tight TB will cause quite a bit of damage to your intermediate shaft bearings and your injection pump input shaft bushing.
Reply #4August 13, 2014, 02:12:55 pm
92EcoDiesel Jetta
Re: belt tension
« Reply #4 on: August 13, 2014, 02:12:55 pm »
Wthout  a belt gauge, that's the approach I take also -just tight enough so it does not flop. I have heard that if you make the belt too tight, it will sing
Reply #5August 14, 2014, 08:36:30 pm
damac
  • 531
Re: belt tension
« Reply #5 on: August 14, 2014, 08:36:30 pm »
Atleast its not as tight as I have seen on some used cars :)
Just curious for those that do their own belt, do you  use the tool on the tensioner?
I don't and I think that stops me from making them too tight.
I move the tensioner to get the slack out with minimal force and then find myself exerting a little extra to nudge it and hold while I tighten the bolt up.
1985 turbo diesel jetta
Reply #6August 15, 2014, 04:20:35 am
Re: belt tension
« Reply #6 on: August 15, 2014, 04:20:35 am »
I try to get 90 degrees with the twist scale. Bentley says use gauge so I will not endorse twist scale and hillbilly it up. FWIW I have seen guys that ran engines from the junk yard that the tensioner was loose and the belt flopping with no valve contact. I don't think there is enough play if it is timed correctly to get valve contact if it is way too loose.
Reply #7August 15, 2014, 06:44:34 am
Re: belt tension
« Reply #7 on: August 15, 2014, 06:44:34 am »
A flapping belt isn't going to cause valve contact on its own if everything stays in place, but it will dramatically increase the chances of skipping a tooth.
Reply #8August 15, 2014, 11:55:07 am
EcoTX
  • 113
Re: belt tension
« Reply #8 on: August 15, 2014, 11:55:07 am »
Here's the Bentley:
I feel like physical strength could influence the "twist by hand" method however.
A bodybuilders twist and my feeble-handed twist are probably a lot different haha.
I weigh 130 lbs and probably can't bench much more than that.
I went out and twisted my belt and it is about 60°-70° I'd say.
Reply #9August 15, 2014, 04:46:58 pm
Re: belt tension
« Reply #9 on: August 15, 2014, 04:46:58 pm »
Another somewhat subjective test that is a little more accurate than the twist is to do the following.  Hook the four fingertips of both hands over the edge of the belt on the cam or injection pump and give it a decent yank towards you.  You should be able to pull it a small amount (1/8" or so).  If you can't budge it at all, it is too tight.  If it slides easily it is too loose.  IMO it is a good idea to get either the belt tension tool and do a couple to spec so you know what the right tension is or to feel the tension on a new properly tensioned late AAZ or AHU/1Z with the automatic tensioner.  The early AAZ and 1.6 should be tensioned similarly.
« Last Edit: August 15, 2014, 04:49:04 pm by libbydiesel »
Reply #10September 08, 2014, 03:20:51 pm
Re: belt tension
« Reply #10 on: September 08, 2014, 03:20:51 pm »
To follow up I checked on it and completely loosened the tensioner and then re-tensioned it like shown in the Bentley as far as how far up to pull up the tool and it seemed to be about the same amount of tension but the belt feels looser now than in the video, you can turn it a little more and you get a little bit of I guess lateral deflection if you want to call it that (pulling it forward) so I think it's good... The Mitsuboshi belt is definitely stiffer than the old Continental ones and a little thicker too I think so they do behave differently.
Reply #11September 08, 2014, 04:03:01 pm
Re: belt tension
« Reply #11 on: September 08, 2014, 04:03:01 pm »
The direction of the wrench when properly tensioned will change slightly from one engine to the next.
Reply #12September 16, 2014, 12:57:16 am
Renax
  • 90
Re: belt tension
« Reply #12 on: September 16, 2014, 12:57:16 am »
I lost my tensioner nut, drove aroud for over a week wondering why it ran so bad at low revs.
When i pulled the cover the belt was only halfway on, but on the right tooth...
After this incident i've been less scared of not thigtening the belt enaugh, and more scared of not thightening the nut enaugh. Locktite is also a good help...
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
Reply #13September 16, 2014, 05:56:09 am
rs899
  • 647
Re: belt tension
« Reply #13 on: September 16, 2014, 05:56:09 am »
Now you have me scared.   I am sure my belt is on the loose side , as it "flops" a bit.  OTOH, I have been running these cars for 20 years now and never skipped a tooth or wore out an intermediate shaft bearing or pump prematurely.
After re-reading the passage in the manual above I see it reads "between the injection pump sprocket and the CRANKSHAFT sprocket"...can you even twist it there?  (that can't be right...the picture shows pump to cam sprocket)
Reply #14September 16, 2014, 06:50:38 am
srgtlord
  • 797
Re: belt tension
« Reply #14 on: September 16, 2014, 06:50:38 am »
That appears to be a typo in that version of the bentley
