General Information
General
winter starting woes
Topic: winter starting woes (Read 5054 times)
July 22, 2014, 01:48:55 am
iamdieselnutmechanic
July 22, 2014, 01:48:55 am »
Well, I am in a spot this year where -40 and lower are very common temperatures... I was thinking I'd like to get marine starting/deep cycle battery in there. Something with 700 or so cranking amps, but 90 or higher Ah rating. I have found one that has a 115 Ah rating.
What do you guys think?
ps. I will be running a 0w40 synthetic for sure.
Hey there, how you doin?
July 22, 2014, 03:51:07 am
Renax
Re:
July 22, 2014, 03:51:07 am »
Biggest battery you can find, only drawback is extra weight...
But for running a Diesel in lower than -40° you need engine and diesel heaters anyways, and about 30% or more paraffin in the diesel, cause just pure diesel would freeze...
Sent from my CATEE CT100 using Tapatalk
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
July 22, 2014, 05:57:41 am
Re: winter starting woes
July 22, 2014, 05:57:41 am »
I went to 1/0 battery cables as well. We only got to -28f this year, but 0 voltage/amperage loss is a good thing.
Round 2
July 23, 2014, 06:41:13 pm
July 23, 2014, 06:41:13 pm »
Canada has very well treated fuel, so there is no worries there on the fuel front. This town I am in is industry run, and %80 of the vehicles on the road are diesel. Extra weight? Haha, this is not a race car. I still averaged 4.5L/100km for 4000kms fully loaded with all my stuff moving here. I would actually love to just put a 4D or 8D deep cycle in my trunk and run huge cables through the cabin lol while keeping the normal battery up front.
I have a group 65 in there now, which is I think for an f-350. But those are a dual battery truck.
Yeah, I think -28 -30 was the line where it wouldn't start anymore. There or warmer was no issue, but colder (few -40's last winter) no chance. This winter is going to be a whole new ball game..
July 23, 2014, 08:15:50 pm
410
July 23, 2014, 08:15:50 pm »
I'm not too far from you but the temps in Fort Mcmoney are consistently 10 degrees colder then here. I think your only real option is a diesel fired heater from webasto or espar. I have a webasto in my car and it fits perfectly in front of the drivers wheel well. They're equivalent to a 5000 watt block heater, draw very little power once fired up and can be set up to turn on with a remote or even your phone. Fifteen minutes of running the heater in the coldest weather and the car will start.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles. Sold!
July 23, 2014, 08:36:44 pm
July 23, 2014, 08:36:44 pm »
I figured as much. Haven't hit the oil yet b'y, ain't made of all the monies lolol.
I like those heaters from my research tonight! They looks damn cool. I have never looked them up before.. but I don't know why these aren't standard options from the factory on Canadian diesels??!
What did yours run you to pick up 410?
July 23, 2014, 09:20:49 pm
410
July 23, 2014, 09:20:49 pm »
I purchased a few off the internet with a buddy of mine but got burned in the end. Together we purchased 4 heaters, 3 of them used. One of the used ones worked and the new one I got for a deal needs to be on a can-buss. Have to spend another 300 for a controller to run that one but it works. If you can find a new one for about a grand you're doing okay. Once you have one of these heaters you can't live without one.
October 27, 2014, 09:02:30 am
spltshft
Newbie
October 27, 2014, 09:02:30 am »
Best thing for a diesel in Alberta is a webasto.
December 12, 2014, 09:32:38 pm
December 12, 2014, 09:32:38 pm »
I did however install a Frost Heater from Terry Frost, and it is plugged in every second it is not running. Works very very well. I haven't used my glow plugs in 3 weeks. At All. Manual setup
no glow needed.
General Information
General
