Author Topic: freshening up a 1.9  (Read 5935 times)
July 17, 2014, 10:22:23 am
spencebm
  • 686
freshening up a 1.9
« on: July 17, 2014, 10:22:23 am »
I need some guidance on what to have done at the machine shop when rebuilding a 1.9AAZ.  Here is what I have come up with.  Please add what you think should be looked at with your experience.  Thanks!
block:
new rings for pistons, check pistons
new rod and main bearings with thrust bearing
check crank-balance? polish?
check/hone cylinder bores
check block deck for flatness
clean block
head: (had about 70k miles when removed)
check for flatness
clean
Ben Spencer
Reply #1July 17, 2014, 01:32:08 pm
Re: freshening up a 1.9
« Reply #1 on: July 17, 2014, 01:32:08 pm »
I would first have the block and pistons looked at. See if there is taper and such. Then the rest can be done. If you need pistons usually the replacement pistons have the wrist pin cut in higher so if you deck the block .005" everything else stays the same. Just check to see what gasket you have now so you know if they cut too much deck you won't be out of spec for the 3 notch.
If you tear into the head, I think it wise to do it all. For sure check to see how flat. If you pull the valves and think a couple need replaced then do all of them...and the guides and seals and etc.
Reply #2July 18, 2014, 03:35:58 pm
spencebm
  • 686
« Reply #2 on: July 18, 2014, 03:35:58 pm »
great.  thanks. anyone else want to add anything?
Ben Spencer
Reply #3July 18, 2014, 05:19:51 pm
Re:
« Reply #3 on: July 18, 2014, 05:19:51 pm »
Theman said exactly what I would have. :-)
Reply #4July 19, 2014, 06:57:42 am
VW Smokr
  • 114
« Reply #4 on: July 19, 2014, 06:57:42 am »
While it's all apart & naked... a few other possible helps for longevity IMO:
1) have rods checked for resizing/re-bushing (& new bolts?)
2) get TDI crank gear & have machine shop modify your crank for the upgrade
3) check intermediate shaft & bearings for condition & placement
4) remove casting flash from intake tracts and the water pump flange & block inlet
5) invest in head studs (some would add other studs also)
Sounds like you want to do it right. Best wishes.
J.R.
SoCal
Reply #5July 19, 2014, 12:06:32 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #5 on: July 19, 2014, 12:06:32 pm »
I agree, everything with a bearing surface should be checked and polished by the machine shop. this is pretty standard procedure.
Also, many machine shops are finding that operating an old school hot tank with oil based solvents while adhering to environmental and safety standards is an expensive proposition, so they have gone to a water based system. My machine shop is one of these, and they pressed the (wrecked anyway) IM shaft bearings out of the block strictly because the hot tank detergent damages bearing materials.
Reply #6July 19, 2014, 06:01:57 pm
RustyCaddy
  • 395
« Reply #6 on: July 19, 2014, 06:01:57 pm »
Someone here, i think it was Tyler, suggested swapping out 7mm valves and guides with 8mm if you are planning on a lot of boost for your rebuild.
Reply #7July 20, 2014, 08:31:16 am
Reply #8July 20, 2014, 01:10:11 pm
spencebm
  • 686
« Reply #8 on: July 20, 2014, 01:10:11 pm »
Thanks for all the good advice!  Explain the magnaflux!
Ben Spencer
Reply #9July 20, 2014, 05:17:08 pm
Re:
« Reply #9 on: July 20, 2014, 05:17:08 pm »
Magnaflux is a process where the block is covered in a metal powder and touched with a magnet. The field lines of the magnet will clearly show any cracks in the block even if they can't be seen with the naked eye.
Reply #10July 20, 2014, 06:10:20 pm
« Reply #10 on: July 20, 2014, 06:10:20 pm »
Buff the pre-chambers until they are shiny and replace them if they have any of the tiny cracks that typically start at the opening of the insert.
Reply #11July 20, 2014, 08:40:30 pm
spencebm
  • 686
« Reply #11 on: July 20, 2014, 08:40:30 pm »
thanks for the explanation and good advice.  I appreciate it.
Ben Spencer
Reply #12July 21, 2014, 07:00:31 am
ftm1776
  • 149
« Reply #12 on: July 21, 2014, 07:00:31 am »
When I worked at Ford Motor Company in the 60s, we had a "wet" magnaflux rig. Wet the part to be check with special fluid and expose it to a strong magnetic field which caused any cracks to be shown as bright lines under a black light. I'm not sure if that is now an outdated method. It was a dream to have all of that gear to rebuild my old Bug !!!! And oh boy did I play !!!!
QUESTION: Just for future reference..............How much money are you talking for all of this work?????? Is it going to be mostly shop work or are you going to DIY some of it?????
Thanks
« Last Edit: July 21, 2014, 07:02:41 am by ftm1776 »
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #13July 21, 2014, 11:27:56 am
92EcoDiesel Jetta
« Reply #13 on: July 21, 2014, 11:27:56 am »
Magnaflux everything
Magnaflux won't work on aluminum so don't bother with the head.
Reply #14July 22, 2014, 06:33:17 pm
spencebm
  • 686
« Reply #14 on: July 22, 2014, 06:33:17 pm »
I'm only having the minimum i can done by the machine shop.  I'm going to try to assemble everything myself.  what do you guys think the cost will be at the least?
Ben Spencer
