Author Topic: 1.6 TD & 1.9 AAZ Intake Gasket ( Neck )  (Read 1948 times)
July 13, 2014, 09:39:34 am
GEE-BEE
  • 1604
« on: July 13, 2014, 09:39:34 am »
I have some extra .075 silicone with fiberglass seal laying around from the leftovers from the aircraft valve cover gaskets I mfg
I sent a AAZ intake to extrude a hone for polishing and I wont use silicone gasket material for the intake neck
I will send the neck to the steel rule die maker and click out some of these seals
let me know if anybody else wants some and I will get some in the mail to you
here is the material shown
http://www.csobeech.com/GeeBee-ValveCoverGaskets.html
I have sold more than 2k sets last month and they work perfect
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
