Author Topic: What is that one wire?  (Read 4788 times)
Reply #15July 13, 2014, 09:09:09 pm
jhax
  • 327
Re: What is that one wire?
« Reply #15 on: July 13, 2014, 09:09:09 pm »
Well for wiring purposes which one is which if there is a dedication?
Reply #16July 13, 2014, 11:14:26 pm
« Reply #16 on: July 13, 2014, 11:14:26 pm »
This is where the glow plug temperature sensor is if you were wondering.
Yes, the oil pressure sensors are different, the one which goes on the oil filter housing operates at a higher pressure, and the are electrical opposites, the one on the head is a simple switch which closes to ground with no oil pressure, turning the LED on. They are marked with the pressure in bar somewhere on the sensor. 1 bar = 14.5 psi.
Reply #17July 14, 2014, 07:26:21 pm
jhax
  • 327
« Reply #17 on: July 14, 2014, 07:26:21 pm »
« Last Edit: July 14, 2014, 08:13:03 pm by jhax »
Reply #18July 14, 2014, 08:13:59 pm
jhax
  • 327
« Reply #18 on: July 14, 2014, 08:13:59 pm »
HAHA!!! SON! BBCode without the
Reply #19July 15, 2014, 02:28:17 am
Toby
  • 728
« Reply #19 on: July 15, 2014, 02:28:17 am »
I think you will find that they are both pretty high and the head might be a tad lower when hot and low RPM.
The one on the head is about 6 psi the one on the OF housing is about 24-28 psi.
If you pitch the relay and bridge the terminals between the light and the head OP sensor it functions just like a regular oil light.
