Author Topic: losing compression around #4 injector  (Read 6981 times)
July 11, 2014, 08:30:57 am
Smoker
  • 255
« on: July 11, 2014, 08:30:57 am »
I cleaned the seat area, replaced the little washer, and torqued the bolt to spec.  I'm still losing compression around the injector. (I can see it bubbling when I spray it down with a little PB blaster)... what am I missing?
Reply #1July 11, 2014, 08:52:33 am
Re: losing compression around #4 injector
« Reply #1 on: July 11, 2014, 08:52:33 am »
You are misconstruing the results of your 'test'.  If you spray solvent around an injector, then when the area heats up, the solvent will bubble out as it evaporates.  The bubbling will happen regardless of whether or not you have a compression leak.  The same thing happens when diesel leaks down around the injector.
Reply #2July 11, 2014, 09:38:20 am
Smoker
  • 255
« Reply #2 on: July 11, 2014, 09:38:20 am »
Interesting.  It wasn't really a 'test'... the head happened to be pretty wet around all the injectors, as I had sprayed it down when I swapped them out.  I just happened to notice it blowing out around the #4 injector but not the others.  When I sprayed more, it continued to bubble around #4 but none of the others.
Reply #3July 11, 2014, 10:28:53 am
« Reply #3 on: July 11, 2014, 10:28:53 am »
Sounds like a fuel leak  needs fixed first.  Was the injector apart or  untested?
Reply #4July 11, 2014, 10:11:23 pm
« Reply #4 on: July 11, 2014, 10:11:23 pm »
Is it bubling out or blowing out.  You've said both and yet, those two symptoms are very different.  If it is forming bubbles that are then popping, I would not have any concern.  If it is spraying the solvent back out without forming bubbles, then I would be concerned.
Reply #5July 12, 2014, 08:18:55 am
Smoker
  • 255
« Reply #5 on: July 12, 2014, 08:18:55 am »
I'll have to try it again and get back to you on that.  When I saw it happening, it gave me the idea that it was blowing out, not boiling, but the more I think about it, the less sure I am...
The motor is actually out of the car now... in the meantime I'm planning on having the injectors pop tested, as I don't know anything about the history of this motor, and I need it to be right.
