Author Topic: AHU BUILD  (Read 12418 times)
July 09, 2014, 12:51:50 pm
GEE-BEE
  • 1604
AHU BUILD
« on: July 09, 2014, 12:51:50 pm »
Removing p/s
keeping a/c assy
Is there a serp setup for this to drive the waterpump ?
Found
http://www.online-teile.com/audi/product_info.php?info=p333851006_028903141ap-halter.html&XTCsid=9e43721193ef35b707967e7e14c2844a
« Last Edit: July 22, 2014, 05:20:48 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1July 09, 2014, 03:44:43 pm
Re: AHU BUILD
« Reply #1 on: July 09, 2014, 03:44:43 pm »
Quantium td split wp pully so crank drives just wp...
Also have 2 kamie nib front rabbit air dams... Look up old 4sale add... Good year ago
Reply #2July 09, 2014, 04:31:34 pm
GEE-BEE
  • 1604
Re: AHU BUILD
« Reply #2 on: July 09, 2014, 04:31:34 pm »
send a pic please
price
[email protected]
PART # OF PULLEY
« Last Edit: July 09, 2014, 05:06:04 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #3July 09, 2014, 05:19:21 pm
GEE-BEE
  • 1604
Re: AHU BUILD
« Reply #3 on: July 09, 2014, 05:19:21 pm »
Found it
Libby posted it
068-121-029 a
shims 068-121-185b
belt 10 x 650
Giles Pump OHC
MK1 JETTA DASH
Reply #4July 09, 2014, 05:33:44 pm
Re: AHU BUILD
« Reply #4 on: July 09, 2014, 05:33:44 pm »
Learn to use SEARCH and you will find bst post and quantium pully info... But i refuse to search on cell phone... And refuse to let local isp people *** me like they want me to allow...
You asked... I replied... My reply stipulates its on the forum... Else id have told you where to search...
Reply #5July 09, 2014, 07:24:29 pm
Re: AHU BUILD
« Reply #5 on: July 09, 2014, 07:24:29 pm »
he replied back...in sales as I am sometimes you need to go the extra mile and search for them if you want it sold. I will search for you this time :D
http://www.vwdiesel.net/forum/index.php?topic=32898.msg306069#msg306069
« Last Edit: July 09, 2014, 07:32:50 pm by theman53 »
Reply #6July 09, 2014, 09:23:09 pm
GEE-BEE
  • 1604
Re: AHU BUILD
« Reply #6 on: July 09, 2014, 09:23:09 pm »
I found the sales ad..
I just asked for current pics of the spoliler that was available
I purchased a new rear spoilerfor the mk1 jetta last week from Germany,
Giles Pump OHC
MK1 JETTA DASH
Reply #7July 10, 2014, 10:54:57 am
Re: AHU BUILD
« Reply #7 on: July 10, 2014, 10:54:57 am »
Tied  up in same rafters they were put after ad made.... Ad does not say either sold... And phone gives ? For any photos... So no help with that... Add has it all... So imo no extra mile required lucas... All i did was confirm they still for sale... I could be a tool and bump it few times a day...
The price will never go down... Just up... So whats it matter if its new ad or not...
« Last Edit: July 10, 2014, 10:57:57 am by CRSMP5 »
Reply #8July 10, 2014, 02:22:03 pm
rodpaslow
  • 670
Re: AHU BUILD
« Reply #8 on: July 10, 2014, 02:22:03 pm »
When I did my 1.6 I just found a v-belt that just drove the power steering (in your case you won't need that) and used the serp belt with a VR6 pulley (on water pump) to drive the alternator and the water pump.  However I did not use the belt tensioner style mount the TDI has for air and .  I found mount just for the alternator and it tensions the belt.   I can provide pics of this if it helps...
Reply #9July 10, 2014, 10:13:28 pm
Re:
« Reply #9 on: July 10, 2014, 10:13:28 pm »
I don't think you can drive the wp via the serp belt if you have the AC compressor in place? There would be basically no wrap on the wp pulley unless you could find a reverse rotation water pump. And I don't believe those exist.
Reply #10July 10, 2014, 10:31:16 pm
Re: AHU BUILD
« Reply #10 on: July 10, 2014, 10:31:16 pm »
The reverse rotation water pumps do exist in the European market but are rare as can be.  Someone posted pics/info on application on this forum.  Personally, I prefer using the locally available parts and like having JUST the water pump on the one belt.  That way all the other serp driven accessories can fail or the belt can break, and I'm still not dead in the water.
Reply #11July 11, 2014, 09:04:32 am
rodpaslow
  • 670
Re: AHU BUILD
« Reply #11 on: July 11, 2014, 09:04:32 am »
I don't have a ac compressor on my car.  the VR6 pulley works the wrong way.  The v's in the serp belt run on the flat surface of the pulley.  I've ran it like that for 4-5 years now without issue.
Reply #12July 12, 2014, 10:27:54 am
GEE-BEE
  • 1604
Re: AHU BUILD
« Reply #12 on: July 12, 2014, 10:27:54 am »
Libby
Do you know this reverse wp part #
Giles Pump OHC
MK1 JETTA DASH
Reply #13July 12, 2014, 08:13:25 pm
Re: AHU BUILD
« Reply #13 on: July 12, 2014, 08:13:25 pm »
Libby
http://www.vwdiesel.net/forum/index.php?topic=9599.30
some stuff on that thread is useful. I think the part # was posted by MJF on there about 3rd page and a couple replies down.
Reply #14July 12, 2014, 10:57:10 pm
GEE-BEE
  • 1604
Re: AHU BUILD
« Reply #14 on: July 12, 2014, 10:57:10 pm »
« Last Edit: July 22, 2014, 05:20:23 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
