How to Prime the Injection Pump??
Topic: How to Prime the Injection Pump?? (Read 3749 times)
July 04, 2014, 08:50:17 am
ftm1776
July 04, 2014, 08:50:17 am »
I read about individuals "priming" the injection pump for one reason or another. I guess one does this after a pump rebuild and for other reasons.
What is the injection pump priming procedure??? Yeah, how do you do it?
Last Edit: July 04, 2014, 10:24:25 am by ftm1776
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
July 04, 2014, 09:30:35 am
Re: How to Prime the Injection Pump??
July 04, 2014, 09:30:35 am »
It is the process of filling the pump with fuel so it is lubed and able to work properly. Anytime the pump is not full of fuel for whatever reason. It is better on the pump than spinning it dry with the starter on the car and it will start easier.
Round 2
July 04, 2014, 10:36:07 am
TimpanogosSlim
Pretty dumb for a smart guy
Re: Re: How to Prime the Injection Pump??
July 04, 2014, 10:36:07 am »
I need to know the how-to as well. My jetta came to me fitted with an electric lift pump, so i figured i could run that for a bit, but other than that i dunno.
. :Sent by pneumatic tubes
July 04, 2014, 10:54:44 am
July 04, 2014, 10:54:44 am »
Pumps, funnel, vacuum on the out bolt, or similar...all you are doing is filling the pump with diesel.
Round 2
July 09, 2014, 11:25:21 pm
July 09, 2014, 11:25:21 pm »
Buy a big syringe and fit some hose to it that will easily fit on the fuel filter. That way you can be sure of only putting clean fuel into your pump. I bought mine at TSC tractor supply in the pet section. Vet use only...
July 10, 2014, 12:01:24 am
Renax
Re:
July 10, 2014, 12:01:24 am »
I have a handpump like the ones you find on the supply line of a outbord engine...
Sent from my P6 using Tapatalk
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
July 10, 2014, 01:34:59 pm
Big Daddy Roth
July 10, 2014, 01:34:59 pm »
I use a vacuum evacuator on the return side of the pump. Make sure to have the stop solenoid energized.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
July 10, 2014, 10:15:04 pm
Re:
July 10, 2014, 10:15:04 pm »
Stop solenoid doesn't matter for filling the pump, it only controls fuel flow to the high pressure head. It has no impact on fuel flowing through the pump.
