S-PAutomotive.com
Author Topic: BEDRUG FOR CADDY  (Read 3461 times)
June 18, 2014, 09:40:51 am
GEE-BEE
  • 1604
BEDRUG FOR CADDY
« on: June 18, 2014, 09:40:51 am »
I will be making another set
The bedrug material will be .250 thickness
http://www.bedrug.com/
Just doing the bed and tailgate, not the side walls
I might make the pattern for the front of the bed also..
I purchased 100 ft of the same hook/loop very heavy duty vecro for the instllation of this mod.
The edges will have marine grade vinyl and under will the female ( loop)sew on
let me know
GB
« Last Edit: June 23, 2014, 01:16:57 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1June 21, 2014, 12:43:32 am
GEE-BEE
  • 1604
Re: BEDRUG FOR CADDY
« Reply #1 on: June 21, 2014, 12:43:32 am »
So far, ordered 100 ft of the 3m female and male dual lock fastner
Bedrug told me of the source and model...
New I will get a used Toyota industrial sewing maching to install the femle backing to the edgeds of the bedrug.
I was thinkink of adding a 1' marinne grade trim o the edges for a complete finish look..
GB
Giles Pump OHC
MK1 JETTA DASH
S-PAutomotive.com
