Author Topic: oil cooler differences  (Read 3963 times)
June 10, 2014, 09:15:32 am
zuhandenheit
  • 196
« on: June 10, 2014, 09:15:32 am »
Hi All,
I'm putting together an AAZ, and am having a little trouble with the oil cooler gasket. My new o-ring seems to be different than the old one. I dug up my 1.6d oil cooler to compare, and it does seem to take the new o-ring. i have two questions:
One, are there different o-rings for the two different oil cooler designs?
Second, since this is going in a vanagon which did have a 1.6, can/should I use the old oil cooler? (The angles of the coolant pipe inlet and outlet are different, which is probably better for my coolant hose configuration.)
thanks!
Reply #1June 11, 2014, 11:05:03 pm
zuhandenheit
  • 196
Re: oil cooler differences
« Reply #1 on: June 11, 2014, 11:05:03 pm »
Sorry about the unnecessarily big pictures.
My most important question about this is whether I would have a problem using the oil cooler from my 1.6d on the AAZ. It looks very different but I would prefer to use the 1.6 cooler.
Reply #2June 12, 2014, 04:50:05 am
« Reply #2 on: June 12, 2014, 04:50:05 am »
same part number for replacement that I see.
Reply #3June 12, 2014, 06:47:16 am
Renax
  • 90
Re:
« Reply #3 on: June 12, 2014, 06:47:16 am »
Just use the 1.6 cooler, older AAZ's has the old cooler stock...
Sent from my cheapchinaphone using Tapatalk
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
Reply #4June 12, 2014, 06:55:41 am
zuhandenheit
  • 196
« Reply #4 on: June 12, 2014, 06:55:41 am »
Perfect. thanks!
Reply #5June 12, 2014, 08:50:14 am
GEE-BEE
  • 1604
engine coolant hoses kit
« Reply #5 on: June 12, 2014, 08:50:14 am »
http://www.thesamba.com/vw/classifieds/detail.php?id=1078372
members here get a special price
I made these years ago for my build
I support the forum as the forum has been a great resource of information
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
