Author Topic: K24 Downpipe stud size  (Read 2577 times)
June 10, 2014, 07:05:59 am
tdrabbit
  • 15
« on: June 10, 2014, 07:05:59 am »
My downpipe studs are all siezed and snapped off on my k24, I'm going to drill and tap them.  The studs are 8mm correct?  I want to go slightly larger to clean and get some fresh threads.   Thanks
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply #1June 10, 2014, 07:12:58 am
Re: K24 Downpipe stud size
« Reply #1 on: June 10, 2014, 07:12:58 am »
m8-1.25. You shouldn't need to go larger if you have a mill or drill press. They are awfully hard to drill sometimes
Reply #2June 10, 2014, 08:22:40 am
tdrabbit
  • 15
Re:
« Reply #2 on: June 10, 2014, 08:22:40 am »
Thanks, yea I don't have either of those, I do have really good machine bits though.  I was able to drill one nearly completely out, there's less than a 1/16" of wall left, but I still can't break the remains apart to pull it out.  Which is why I figured on just drilling the whole thing out and starting new.
Reply #3June 10, 2014, 09:05:56 am
Re:
« Reply #3 on: June 10, 2014, 09:05:56 am »
Lots and lots of heat should do the trick. The turbine housing can definitely take it.
Reply #4June 10, 2014, 10:09:43 am
tdrabbit
  • 15
Re: Re: Re:
« Reply #4 on: June 10, 2014, 10:09:43 am »
Yea i tried that, they snapped flush with the housing :/
