Author Topic: Sealing PS steering U-Joint shaft  (Read 8660 times)
June 02, 2014, 06:32:28 pm
DogDiesel
  • 210
« on: June 02, 2014, 06:32:28 pm »
My PS works great on my 1981 VW Caddy Pickup.
However, the original shaft plug does not work right, the joint simply pushes it out, and in the winter quite a draft.
The joint on the PS sit and fits right at the firewall hole.  I have had it wrapped in insulation for the last 5 years, but that is a poor fix.
Though of a 2 piece temp CV boot, took it back, too stiff and shaft hole to large
Thinking of using an old outer CV boot.  Split, and wrap around shaft, and overlap.  Lacing wire  or wire ties in several boot grooves to hold.  Fix to floor.  Anybody got a better idea?
« Last Edit: June 02, 2014, 06:40:25 pm by DogDiesel »
Reply #1June 04, 2014, 06:46:52 am
GEE-BEE
  • 1604
Re: Sealing PS steering U-Joint shaft
« Reply #1 on: June 04, 2014, 06:46:52 am »
I can/ you can make a round seal
small hole to match o.d. of shaft
small slits outward from the center hole ( 6/8 )
pop rivet in place
thus will require to remove shaft thou
I stock 1/16 and 3/32 black silicone seal with fiberglass insert
I mfg aircraft engine valve cover gaskets, some aircraft have 12, the large radials have 72 valve covers per engine
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2June 04, 2014, 07:47:32 am
DogDiesel
  • 210
« Reply #2 on: June 04, 2014, 07:47:32 am »
I would be interested, however, on a different topic of a long rubber hose from water pump to left sided bottom inlet Schirrocco race radiator.  I was forced to use this radiator with AAZ with AC and serpentine because the lower radiator hose rubbed the hose plus there was no way to connect ac hoses and have lower right hose.  I can provide PN of hoses I used.
For this joint/shaft cover I have a new CV boot to wrap and pop rivet without pulling and sliding boot over shaft.
Believe I won't be the last to use serpentine and want AC in Caddy.
Wayne
Reply #3June 04, 2014, 07:53:02 am
DogDiesel
  • 210
« Reply #3 on: June 04, 2014, 07:53:02 am »
I have PN for radiator thermo sender too.  This radiator is superior to every OEM radiator I have uses andI can run freeway plus speeds and needle in dash don't move.  That is with Giles pump an lead foot.
  I have designed lower radiator hoses so starter can be pulled with hose mounted.  What I am unsure of is whether there is room for an aftercooler and piping. Have kit to install and find out though.  Will post when done. Also need to connect & charge AC.
Fairly certain others may want to pattern build.
Wayne
« Last Edit: June 04, 2014, 08:04:43 am by DogDiesel »
Reply #4June 04, 2014, 08:18:45 am
GEE-BEE
  • 1604
HOSE RAD
« Reply #4 on: June 04, 2014, 08:18:45 am »
off topic
for the td radiator use
lower hose 191-121-051 p
upper 191-121-101 q, this hose does not have return to tank
FITS 1.6, 1.9 AAZ /AHU INSTALL
Giles Pump OHC
MK1 JETTA DASH
Reply #5June 04, 2014, 08:41:47 am
DogDiesel
  • 210
« Reply #5 on: June 04, 2014, 08:41:47 am »
BTW:  my aftercooler is a Calloway kit.
Wayne
Reply #6June 04, 2014, 08:56:05 am
GEE-BEE
  • 1604
« Reply #6 on: June 04, 2014, 08:56:05 am »
Wayne are you going to let me make the silicone hoses, instead of the hard tubing ?
or did you install ?
Gb
Giles Pump OHC
MK1 JETTA DASH
Reply #7June 04, 2014, 04:34:48 pm
DogDiesel
  • 210
« Reply #7 on: June 04, 2014, 04:34:48 pm »
I have installed lower hoses using two separate hoses and a 6" metal step up size adapter .  I support the hose at the metal center. Originally I had a longer metal tube but after Giles pump need more flex.  Was getting minor coolant leaks after hard run. Fine when driven civilally.  Need to install Calloway to see fitment.  Currently, I can't make it leak.  I launched so hard I snapped boltheads off left CV shaft to flange.   No leak.  Design works. Can remove & replace starter without dropping coolant. Now need to see if Calloway kit will have interference.  MTF
Reply #8June 08, 2014, 10:11:29 am
  • 1739
« Reply #8 on: June 08, 2014, 10:11:29 am »
I would just coat it with a ton of anti-seize. It won't wash off too easily and you won't have to go through the trouble of taking it off etc.
