Author Topic: Timing Q  (Read 1930 times)
June 01, 2014, 01:14:41 pm
Big Daddy Roth
  • 298
Timing Q
« on: June 01, 2014, 01:14:41 pm »
AAZ w/ Giles pump and Dr. Diesel cam.
What do you figure my pump timing should be?
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1June 01, 2014, 05:21:00 pm
Re: Timing Q
« Reply #1 on: June 01, 2014, 05:21:00 pm »
how much boost are you running and what turbo? If you are running a k14 intercooled to 20psi, I would run it around .90 to .95 mm tops. I like .94mm the best for my setup. Less timing seems like more with his pumps. That is the info I have on the 1.6 stuff, but if the aaz has less timing to begin with you may just go .05-.10 mm less than what stock is.
Also, you could just get ahold of him and ask come Monday
« Last Edit: June 01, 2014, 05:22:51 pm by theman53 »
