Author Topic: First Time Checking Pump Timing..Questions??  (Read 2856 times)
May 27, 2014, 06:38:14 pm
ftm1776
  • 149
« on: May 27, 2014, 06:38:14 pm »
I checked the injection pump timing for the first time today. I just wanted to get used to the procedure and using the two-turn dial indicator; 0.50mm per rotation. It was right on the money at 0.9mm. I moved the crank and did it again for practice. So, I didn't have to change the pump position.
I seems reasonable that the metal fuel lines should be loosened and re-tightened at some point. Yes? Bentley doesn't mention it.
Also, I fitted the pump locking pin into its position. I bought it on Ebay. It doesn't fit as snug as I thought it would.
Should it be a pretty snug fit? It's 0.594" dia.; my 11 mm socket is .611".....Youtube guy says 0.615...I've seen some
have to tap it in with a hammer !!
Comments??
« Last Edit: May 27, 2014, 06:42:23 pm by ftm1776 »
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1May 27, 2014, 08:54:04 pm
8v-of-fury!
Re: First Time Checking Pump Timing..Questions??
« Reply #1 on: May 27, 2014, 08:54:04 pm »
Does not matter one bit. That only locks the pulley in place for installing the belt, really. It would need to be small enough (loose) so that the belt could slip a full tooth for it to matter any at all..
A hammer? What a pain in the ass.
Reply #2May 30, 2014, 10:53:59 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #2 on: May 30, 2014, 10:53:59 pm »
yes you should relax your hard lines.
Reply #3May 31, 2014, 08:38:33 am
8v-of-fury!
« Reply #3 on: May 31, 2014, 08:38:33 am »
^^ When moving the pump yes. If you only checked timing without rotating the pump, it is unnecessary.
Reply #4June 01, 2014, 11:50:00 am
air-cooled or diesel
« Reply #4 on: June 01, 2014, 11:50:00 am »
my pin and cam lock are blue point, much better than most tools; use a plastic hammer if you absolutely have to. check vince's link for timing and using dial gauge.
