Author Topic: The Sound of Solenoids  (Read 6601 times)
May 23, 2014, 07:19:27 pm
ftm1776
  • 149
« on: May 23, 2014, 07:19:27 pm »
My car: 1991 MK2 1.6 diesel, NA
The injection pump was recently rebuilt by a reputable diesel specialty shop in Portland, OR…..Diesel Fuel Injection Service. I has the two solenoids; fuel shutoff and cold start.
They look the same, but have different Bosch part numbers.
The fuel shut valve will make an obvious “click” when energized with a 12 volt lead.
The cold start valve makes no such sound. Thinking the wire to it might be temperature controlled, I jumped directly from the battery…….still no click.
I tried to remove the cold start valve using a large crescent wrench, but it felt too tight and I didn’t want to break anything. The aluminum housing doesn’t look to strong. I put some WD-40 on and left it till tomorrow.
One of the techs at DFIS told me that some of the Bosch solenoids cannot be heard very easily.
Should the cold start solenoid make an audible click when energized with 12 volts directly from the battery???
If not, can I take that as a sign to replace it??
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1May 23, 2014, 07:30:55 pm
Re: The Sound of Solenoids
« Reply #1 on: May 23, 2014, 07:30:55 pm »
Not sure you have a cold-start solenoid... is there a lever in the cabin?
There sometimes are other solenoids by the timing plunger... ALFB (interruptible load sensitive start of delivery ) being one.
If you have a pic, it will help.
Reply #2May 23, 2014, 08:50:54 pm
thomas m
  • 144
« Reply #2 on: May 23, 2014, 08:50:54 pm »
Picture of what I call the "cold start solenoid"........some pumps don't have it.
It's in there pretty tight and that housing is dainty....I suppose I could grap the aluminum housing with a padded pair of channel lock pliers and put a little more twist to it?????
I just want to know if I should be able to hear it activate. If yes, I might have to replace it.
Yes, there is a cold start pull handle to the left of the steering wheel.
« Last Edit: May 23, 2014, 09:50:49 pm by thomas m »
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
Reply #3May 24, 2014, 04:59:22 am
« Reply #3 on: May 24, 2014, 04:59:22 am »
You probably won't hear that one. That's an ALFB.
"The ALFB can be deactivated to reduce HC emissions generated by the diesel engine when it is cold (< 60'c). This process employs a solenoid valve (8) to block the fuel. This solenoid valve is open when de-energized."
ALFB will retard timing unless the solenoid has power.
Reply #4May 24, 2014, 09:26:03 am
ftm1776
  • 149
« Reply #4 on: May 24, 2014, 09:26:03 am »
How do I know that it is functioning correctly?? (I can't find it on my Bentley wiring diagram.)
Or at least that it is getting power when it is suppose to get power??
I can't tell that the solenoid is activating unless I remove it and look....maybe not even then.
Bottom line is that if it doesn't affect engine start, idling or anything else I'd just as soon not have it on the pump,
but will have to live with it, I guess.
PS: I think I see. When the engine is running at less than 60C or 140F, the ALFB would be de-activated by 12 volts to the solenoid until the engine warms up. So, I should see 12 volts at the solenoid, just after start-up, with the engine cold, i.e., less than 140F. Once above 140F, there should be no voltage at the solenoid and it would be open. I hope that's right.
« Last Edit: May 24, 2014, 12:24:01 pm by ftm1776 »
293,000 miles
Reply #5May 24, 2014, 11:15:08 am
mtrans
  • 308
« Reply #5 on: May 24, 2014, 11:15:08 am »
put light bulb in series with solenoid,if light is on than 99% is OK.
I`ll improve my English
Reply #6May 24, 2014, 12:13:01 pm
Re:
« Reply #6 on: May 24, 2014, 12:13:01 pm »
Most of those should just have +12V all the time. They have no effect at idle at all really, it's 1800+ RPM where you will notice whether it is working or not.
Reply #7May 24, 2014, 12:27:41 pm
ftm1776
  • 149
« Reply #7 on: May 24, 2014, 12:27:41 pm »
I have not yet seen 12 volts at the solenoid.....checking with my voltmeter, regardless of temperature condition.
I'll keep on probing around. There must be some sort of relay that sends 12 volts though the red/black wire to the solenoid and it should be controlled by a temperature sensor.
« Last Edit: May 24, 2014, 12:41:15 pm by ftm1776 »
293,000 miles
Reply #8May 24, 2014, 01:27:04 pm
« Reply #8 on: May 24, 2014, 01:27:04 pm »
Parallel would probably be better. Hook it up on your dash somewhere temporary and see if it ever comes on. I've never owed a car with that style before so I don't know anything about it's specific wiring.
If you don't see it coming on, tee it in with the stop solenoid and see if there is any difference. If there is, leave it teed in, if not then leave it unhooked.
Reply #9May 24, 2014, 03:47:09 pm
Re:
« Reply #9 on: May 24, 2014, 03:47:09 pm »
I think he's meaning if you put the bulb I'm series it will confirm that the solenoid is operating. Ie that it doesn't have a broken wire internally. More of a test light than an ongoing display.
With regards to not seeing 12V, remember it is emissions logic. God knows what was supposed to control it, if whatever that was is still present and whether whatever that was is operating correctly. Try just connecting 12V to it and driving.
Reply #10May 24, 2014, 09:55:23 pm
ftm1776
  • 149
« Reply #10 on: May 24, 2014, 09:55:23 pm »
I am the original owner of this vehicle and I don't remember removing any emissions components.
As stated, this pump has recently been completely rebuilt by a reputable diesel specialty shop that focuses on diesel injection ONLY. No other car or truck repairs. I'm going to go in and ask them about it. Of course, they can't speak for anything but the pump. I know that the solenoid is not energized when the engine is cold....haven't check it hot though.
I'd like to get rid of this gadget and the silly altitude compensator and the power steering and the power brakes.....I want it simple !!!, but will have to prioritize my modifications and take care of necessary things first......maybe an old Rabbit diesel.....why did I get rid of my 78 D ??!!!
293,000 miles
Reply #11May 25, 2014, 04:44:25 am
« Reply #11 on: May 25, 2014, 04:44:25 am »
Sometimes it's better to keep things working in the original config, or they get problematic... like parking brakes.
The ALFB is nice since it stops the IP from retarding when cold.
The altitude compensator is good since it can reduce EGTs in the mountains. It would suck to have those parts get sticky or binding from lack of action, since they affect max fueling.
Reply #12May 25, 2014, 02:37:20 pm
mtrans
  • 308
Re:
« Reply #12 on: May 25, 2014, 02:37:20 pm »
Right on,I`ll like to know if you use swich to operate this,what you get.
Reply #13May 25, 2014, 03:48:01 pm
Toby
  • 728
« Reply #13 on: May 25, 2014, 03:48:01 pm »
Try putting 12v to the solenoid when its running and see if there is a difference. I had a Volvo 6 banger diesel and it ran like crap with the wire off. Just fine hooked up. It made a significant difference at idle as well.
