Author Topic: WTB: 1Z or AHU with 0 miles rebuilt or new.  (Read 10242 times)
May 20, 2014, 10:35:00 pm
markdelevo
  • 30
« on: May 20, 2014, 10:35:00 pm »
hi, as the title says i like to buy 1Z or AHU with 0 miles.I would be interested in to buy fully custom high power build either. Please pm me with info and price. Thanks in advance
Reply #1May 21, 2014, 05:26:25 am
Re: WTB: 1Z or AHU with 0 miles rebuilt or new.
« Reply #1 on: May 21, 2014, 05:26:25 am »
Please put your location in your profile.
I could build one 5,000.00 and a few months. FOB origin
Reply #2May 21, 2014, 07:20:37 am
GEE-BEE
  • 1604
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3May 21, 2014, 08:56:01 am
markdelevo
  • 30
« Reply #3 on: May 21, 2014, 08:56:01 am »
Please let me know details about build thanks.
Reply #4May 21, 2014, 06:39:13 pm
GEE-BEE
  • 1604
« Reply #4 on: May 21, 2014, 06:39:13 pm »
The price is all about what pistons/rods/cam/turbo/intake/pump/head work
Then you have to build a trans to handle the HP
The caddy was the cheap part for me
I purchased a ahu and trans for 1400.00 from one of my dealers, sold the wiring harness and ecu
now somebody wants the turbo and pump
watch the samba for deals on engines in running condition
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5May 21, 2014, 06:42:01 pm
« Reply #5 on: May 21, 2014, 06:42:01 pm »
Show me the money and your location :D
Reply #6May 21, 2014, 07:23:43 pm
markdelevo
  • 30
« Reply #6 on: May 21, 2014, 07:23:43 pm »
My best goal would be a plug and play motor with and injection pump,lines,injectors ,t-belt already installed (no need any other acc)and needs to be reliable while reaching high bhp.
But i am open to offers.
Budget is all depends on the work will be done. So i need to know what you can do and references Please.
Means i have the money but will spend it for the right job.
Why i am doing this : because my time is very limited and i have to get my vehicle ready before i install the engine and i have no experience to build reliable high powered tdi engine other then that basic rebuild won't be an issue . I just don't wanna spend my time on something i haven't had any experience yet(i have no luxury to do guess work) Also my transmission will be build to reach my expectations.
Thanks.
Reply #7May 21, 2014, 07:24:49 pm
markdelevo
  • 30
Reply #8May 22, 2014, 06:06:06 am
« Reply #8 on: May 22, 2014, 06:06:06 am »
Thanks.
I have an aaz engine that I am converting to an AHU with the 1st oversize pistons. The build would be coated pistons, ported cylinder head, new valvetrain, new bearings and gaskets, head studs, main studs, balanced rotating assembly, and possibly more if you needed it. What turbo would you use? What goals would you have? Etc. I have built many engines and a few diesels. The build thread part 2 is the latest and best diesel I have built.
I would want at least 1/2 up front and a contract that I am not liable for your stupidity.
Reply #9May 22, 2014, 06:59:17 am
GEE-BEE
  • 1604
« Reply #9 on: May 22, 2014, 06:59:17 am »
Just dont buy a high mileage engine from German Motors in Ontario calif
He pays about 200-300 per engine from europe and sells for a crazy markup, you dont know whats inside
I did a AAZ from him, pulled the head...
I rebuilt the pump/turbo, new head etc.
Easier to start with new assy or have a core built up to your spec
VWtransaxle did my last build o20 custom, fair price
I did powdercoat the trans housing and supply the arp hardware
Giles Pump OHC
MK1 JETTA DASH
Reply #10May 22, 2014, 08:26:04 am
« Reply #10 on: May 22, 2014, 08:26:04 am »
Thanks.
You can not convert an AAZ to TDI, only mTDI. There is no boss in the block for the crank sensor pickup.
Reply #11May 22, 2014, 04:21:21 pm
markdelevo
  • 30
« Reply #11 on: May 22, 2014, 04:21:21 pm »
converting AAZ to AHU? no thanks . I think you misunderstood me. I definitely know diesel engines and specially tdi's.  i just dont have enough time right now
Thanks.
Reply #12May 22, 2014, 04:58:06 pm
Re:
« Reply #12 on: May 22, 2014, 04:58:06 pm »
I assumed that you wanted m TDI otherwise why wouldn't you go alh?
An aaz can be easily converted to a TDI like the ahu with the proper parts. Just not the e TDI easily, a piece could be made for the crank sensor.
Reply #13May 22, 2014, 05:31:18 pm
markdelevo
  • 30
« Reply #13 on: May 22, 2014, 05:31:18 pm »
because i am building vw T4 sportsmobile and 1.9 Ahu or 1z is the best way to go . I already have an Aaz in but cant reach power and reliability with it.
Reply #14May 22, 2014, 05:37:03 pm
« Reply #14 on: May 22, 2014, 05:37:03 pm »
Are you going E TDI, yes or no?
If not then you can go M TDI with an AAZ block and the TDI rotating assembly
