Author Topic: Keeping it cool ( FLEX A LITE FAN ASSY 330 ) MK1-MKII  (Read 14235 times)
May 16, 2014, 01:07:45 pm
GEE-BEE
  • 1604
« on: May 16, 2014, 01:07:45 pm »
This will fit lots of rad's
26-1/2 wide
15 ' Tall
2-5/8 deep
I will be going to again a TD radiator assy 675mm wide
Lower hose from Scirocco 16v
http://www.ebay.com/itm/VW-Mk2-Golf-Jetta-GTI-GLI-16V-Diesel-8V-Lower-Radiator-Hose-Lifetime-Silicone-/220726183290#ht_3565wt_983
Upper
http://www.ebay.com/itm/VW-Mk2-Golf-Jetta-Upper-Radiator-Hose-Lifetime-Silicone-/220726223913?pt=Motors_Car_Truck_Parts_Accessories&hash=item33644ee429&vxp=mtr#ht_3234wt_983
These can be made in any color
The radiator will fit 1.6 td/1.9 aaz and ahu
Iam getting a freebie from Flex A Lite for mockup...
GB
« Last Edit: November 21, 2014, 05:33:22 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1May 16, 2014, 02:27:13 pm
wolf_walker
  • 1205
Re: Keeping it cool ( FLEX A LITE FAN MODEL 412 ) MK1-MKII
« Reply #1 on: May 16, 2014, 02:27:13 pm »
I was wondering awhile ago what the cfm of the stock fan is.
Mentat Text Two
Reply #2May 16, 2014, 05:45:26 pm
GEE-BEE
  • 1604
« Reply #2 on: May 16, 2014, 05:45:26 pm »
the OEM its only a single speed, 3 blades ?
This twin is very efficent and  it covers the complete radiator and is multi speed
the thin will help with the intercooler , as I can move the radiator closer/ rearward...
http://www.flex-a-lite.com/catalogsearch/result/?q=412
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3May 19, 2014, 01:02:56 am
wolf_walker
  • 1205
« Reply #3 on: May 19, 2014, 01:02:56 am »
I suspect someone good with math can measure the surface area of the stock fan and knowing it's RPM, calculate it's CFM.
I've thought about replacing it a number of times just for the sake of making less clutter and more room in the engine bay,
but units I thought via guessing would be sufficient were cost prohibitive for fixing something that isn't broken in a stock
application.  Interested to hear how it performs.
Mentat Text Two
Reply #4May 20, 2014, 12:49:24 pm
jaed_43725
« Reply #4 on: May 20, 2014, 12:49:24 pm »
$400.00. That is what will keep me from getting that. Also they posted 2,500 cfm on the Flex-A-Lite website.
Reply #5May 20, 2014, 05:20:33 pm
wolf_walker
  • 1205
« Reply #5 on: May 20, 2014, 05:20:33 pm »
Yeah, the cost to match or better the stock fan's, assumed, output is pretty high.
And they last forever even if they are huge and bulky.  Still cool though.
Mentat Text Two
Reply #6May 21, 2014, 06:57:43 am
GEE-BEE
  • 1604
« Reply #6 on: May 21, 2014, 06:57:43 am »
283.00 PLUS FHT
http://www.amazon.com/Flex-lite-412-Lo-Profile-Electric/dp/B003ZKATM6
The truck is the cheap part in the build...
Giles Pump OHC
MK1 JETTA DASH
Reply #7May 25, 2014, 03:23:41 pm
« Reply #7 on: May 25, 2014, 03:23:41 pm »
I'm not sure how these compare to VW fans but this was an issue people ran into in the Jeep community I was a part of, that aftermarket electric fans often did not exceed, or even match, the airflow of OEM electric fans or even the mechanical fan. This is something I would have to know before buying.
Reply #8May 25, 2014, 09:37:37 pm
GEE-BEE
  • 1604
« Reply #8 on: May 25, 2014, 09:37:37 pm »
Iam sure you have seen a three blade mk1 fan correct ?
If you take a kesterl wind gauge you would understand the different flow between the two assys
This model covers the complete radiator ( shrouud ) the stock is just a partial
nite and day difference
Most people wont do this mod as the cost is a little high, Iam reducing three inches of room to my install..
GB
« Last Edit: June 22, 2014, 04:08:58 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #9May 26, 2014, 05:41:37 am
« Reply #9 on: May 26, 2014, 05:41:37 am »
Iam sure you have seen a three mk1 fan correct ?
GB
I love the idea of reducing the depth takes to mount it on the radiator. You could move the radiator back and run A/C condenser up front. If you wanted
Reply #10May 26, 2014, 06:25:36 am
GEE-BEE
  • 1604
« Reply #10 on: May 26, 2014, 06:25:36 am »
100% correct
Same hoses, just trim to length, moving the battery really gives room so both in and out tubes from the intercooler are on the drivers side..
http://www.darksidedevelopments.co.uk/products/darkside-twin-pass-front-mount-intercooler-fmic.html
This one is perfect for a universal
Giles Pump OHC
MK1 JETTA DASH
Reply #11June 22, 2014, 08:52:26 am
southernman
  • 72
« Reply #11 on: June 22, 2014, 08:52:26 am »
I started out with the 3 blade single speed fan on a truck that came with A/C (factory adder sans AC parts). This motor didn't have a 'high speed' option which engages with the compressor.
The factory replacement 6 blade cooling fan cost <$20 and a new replacement 2 speed motor cost <$30 from Rock Auto...
I had already replaced the radiator, hoses, with a 180 thermostat before adding the 6 blade/2 spd assy.
When wiring it in, I simply wired it to run off the "high" speed terminals anytime the thermal switch was made at ~210 degrees F. Of note - you CAN wire these motors to run backwards if you're not paying attention. They're not shaded pole or...so they will run in bot directions.
Under normal driving, the engine runs right on the thermostat at 180 degrees; same with highway cruising at 70-75mph.
When the temperature does trip the thermal switch, it returns to 180 degrees in about 1 minute; about 2 minutes if it runs on 'low' fan speed setting.
I'd have to agree with others relative to cost here; it wouldn't be worth an additional $300 to gain seconds on my cooling cycle. If your setup it tight (no leaks) and in good condition, it's gonna be tough to beat the factory stuff when everything's working properly.
Southernman
'82 VW Caddy w/ 1.6 NA Diesel - completely stock.
Reply #12June 22, 2014, 04:06:01 pm
GEE-BEE
  • 1604
« Reply #12 on: June 22, 2014, 04:06:01 pm »
Its about going to 2.25 depth if adding a intercooler in front of the a/c condenser.
With this fan you can move the 26 ' wide scirocco radiator or the stock 22 all the way back to the end of the core support .
I got a freebie and I will be making the a/c version Callaway intercooler kits and his wont relly be needed, but I still like this as it covers the 26 ' wide core of the radiator ..
The intercooler is avaiable from Bell Intercooler
I pickedup another complete AHU with ctn trans over the weekend for 750.00 and a very nice 1981 MK1 Jetta coupe to install it in after complete
paint.
Another AHU build to keep my hands busy with my son.
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #13June 25, 2014, 10:12:40 am
92EcoDiesel Jetta
« Reply #13 on: June 25, 2014, 10:12:40 am »
My 92 Eco has dual fans each with 12 blades, driven by a belt via an electric motor with 2 speeds, controlled by the rad temp switch. I have zero problems with it keeping the temperatures in check. I can't see an aftermarket setup being any better cooling wise than the OE other than maybe thinner and take up less room.
Reply #14June 30, 2014, 01:08:34 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #14 on: June 30, 2014, 01:08:34 pm »
Ah, but that extra room is so nice when digging around under the hood, not to mention aesthetics  8)
I think I spent $50 on two 'chinese special' ebay fans; they keep my temp guage centered perfectly, and I love the extra room. If (when ::)) they crap out I'll just throw the old unit back in for a quick fix, and hopefully have money to get a better quality pair of fans. After going slim profile, I can't see going back to the stock unit as a permanent thing.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
