Author Topic: Custom 1.9 Mk1 Downpipe 2.5 I.D. ( GTB1756 VK )  (Read 4860 times)
May 12, 2014, 12:05:58 pm
GEE-BEE
  • 1604
« on: May 12, 2014, 12:05:58 pm »
I spoke with TT and they will make the 1.9 Downpipe to match the GTB1756 VK  model
http://techtonicstuning.com/main/index.php?main_page=index&cPath=2_11_4_284
Iam sending the exhaust and turbo for this complete mockup  fot the 2.5 1.9 ahu downpipe
I ordered a custom 2.5 Borla S/S exhaust assy today also for the caddy build
Moving forward everyday
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1May 12, 2014, 03:41:45 pm
Re:
« Reply #1 on: May 12, 2014, 03:41:45 pm »
You are going to LOVE the turbo. I am still tuning my control system but it is insane how fast it can generate boost. It has absolutely no problem burying the needle of my old 25 PSI gauge in to the stop at a fairly low RPM. Heck I can make boost at idle if I let it close the vanes all the way...
Reply #2May 12, 2014, 04:43:25 pm
GEE-BEE
  • 1604
Re: Custom 1.9 Mk1 Downpipe 2.5 I.D. ( GTB1756 VK )
« Reply #2 on: May 12, 2014, 04:43:25 pm »
Iam doing all mcnally gauges for the center console
http://mcnallyelectronics.com/
Giles Pump OHC
MK1 JETTA DASH
Reply #3May 12, 2014, 06:28:04 pm
« Reply #3 on: May 12, 2014, 06:28:04 pm »
I like the look of those. Look almost like the auto meter cobalt, only would fit the vw well
Reply #4May 12, 2014, 06:46:29 pm
GEE-BEE
  • 1604
« Reply #4 on: May 12, 2014, 06:46:29 pm »
They work perfect, I installed in the other build
New build will be close to 40 psi..
parts is parts...
My aircraft valve cover gaskets are selling like hot cakes...
Giles Pump OHC
MK1 JETTA DASH
