Author Topic: Add "W" terminal wire to Bosch/Valeo serp-belt TDI alternator  (Read 67817 times)
Reply #15September 25, 2014, 08:51:40 am
rodpaslow
  • 670
Re: Add "W" terminal wire to Bosch/Valeo serp-belt TDI alternator
« Reply #15 on: September 25, 2014, 08:51:40 am »
Yeah, I have an alternator that has the W and installed it last night - was from the 2.0 ABA.  Works fine.  I have a new VDO tach, just have to set the pots later today and also has a potentiometer so if it's off a bit I can adjust it.  I bought a cheap china electronic hand held tach, Just add a piece of it's reflective sticker to the crank and it tells speed - seems like it works well enough.  Will adjust the VDO to match it - cause I hate not having a tach.
Thanks for the help!
Reply #16September 26, 2014, 09:07:46 am
rodpaslow
  • 670
« Reply #16 on: September 26, 2014, 09:07:46 am »
I now have a working tach -  current idle is about 786, by my cheap china hand held, so I set it to just below the 800 mark.
W alternator is so much easier than finding a winding before the doide on this type of alternator - in my opinion.  I'm have virtually no electronics experience ...
Reply #17January 11, 2016, 06:01:47 pm
rotaecho
  • 33
« Reply #17 on: January 11, 2016, 06:01:47 pm »
I'm also getting ready for a mTDI (AHU) conversion in my Westy as well and was looking for an alternator that would mount to the block that would accept the W terminal.
Reading this post the AL0184X would be a good way to obtain the W terminal.
I have the following questions:
Does this alternator have the same/similar RPM setups for the diesels?
What is required for getting the proper Tach RPM's setup for an mk2 (CE1 diesel tachometer?) configured properly for RPMs? Should an m-TDI AHU idle around 750?
Thanks! Really hoping to get a tachometer solution figured out for my conversion.
-Will
1982 Westfalia 1.6na diesel aka Betsy Bertha The Tortoise
Reply #18January 21, 2016, 11:19:08 pm
« Reply #18 on: January 21, 2016, 11:19:08 pm »
I have the AL0184X on mine... Works fine.
The tach you have should just plug in and work if it's for a diesel.  No magic... Not sure if there is an adjustment on those older ones, I don't think there is.  The tach will be approximately right though.
Reply #19January 22, 2016, 06:20:21 am
« Reply #19 on: January 22, 2016, 06:20:21 am »
There is an adjustment pot in the circuit of each of the tachs back to mk1.
Reply #20February 11, 2016, 07:52:08 pm
rotaecho
  • 33
« Reply #20 on: February 11, 2016, 07:52:08 pm »
Thanks Libby, sounds like a better option for a mTDI setup would be using the AL0184X with the W terminal. That way there's no prying off the plastic back and soldering a wire to a stock TDI alternator.
-Will
Reply #21April 05, 2020, 09:06:47 am
Achilles3588
  • 12
« Reply #21 on: April 05, 2020, 09:06:47 am »
Swapping a 1.6 TD JX for a 1.9 mTDI AFN in a '91 Syncro Doka.
The bright shiny new Bosch Alternator Model No. AL0723X that came with the AFN does not have an explicitly W signal, rather B+, D+ and finally DF. I have seen pics above of the AL0184X where the W connection is exactly where the 0723X places the DF in a two pin connector. When looking at AHU wiring schematics it appears the DF signal is effectively equivalent to the W but that's a simplified schematic and is without looking at the alternator internals or the mfr's internal schematic. Does anyone know if the connecting the JX's W wire to the alternator's DF terminal will accomplish the tach signal objective? I don't want to void the warranty on the new alternator by making the above mods.
'91 1.9L TDI 'AFN' Syncro Doka
Reply #22April 05, 2020, 05:13:35 pm
« Reply #22 on: April 05, 2020, 05:13:35 pm »
The AHU alternators I have used have had the W terminal as a marked connection.  I have not used an AFN alt.
Reply #23October 26, 2021, 11:24:50 am
Frankly21
  • 2
    • cas
« Reply #23 on: October 26, 2021, 11:24:50 am »
Check your brushes and if not, see maybe where the cable does not connect at the alternator, how it connects
