Author Topic: What exhaust manifold for relocationg the turbo?  (Read 4959 times)
April 28, 2014, 08:10:25 pm
Diesel_Zuk
  • 182
« on: April 28, 2014, 08:10:25 pm »
I'm doing a 1.9 mtdi ahu into my 86 samurai. I was just looking at it today, and came to the conclusion that if I can have my turbo higher up, like on an aaz motor, it will be out of the way of my motor mount, and alternator. Will an aaz manifold work with the triangle flange of my k03? Also, if it does, won't I possibly have to rotate the body of the turbo in order to keep the drain at the bottom of the body? The plan would be to get a flexible supply line most likely.
Reply #1April 28, 2014, 10:18:04 pm
Re:
« Reply #1 on: April 28, 2014, 10:18:04 pm »
I used a 2005 Passat manifold on mine. The turbo is much higher than stock. It points mostly straight out with a slight downwards angle.
Yes, you will need to clock the turbo if you change its angle. Not usually too big a deal on a wastegate turbo.
Reply #2May 08, 2014, 10:39:27 am
GEE-BEE
  • 1604
Re: What exhaust manifold for relocationg the turbo?
« Reply #2 on: May 08, 2014, 10:39:27 am »
1.9 AAZ is high, there are two versions
K03 or K14
K14 is early model
Iam going as high as possble for the AHU as its too low on my MK1 rabbit
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3May 08, 2014, 05:56:07 pm
« Reply #3 on: May 08, 2014, 05:56:07 pm »
you could buy or make a spacer and weld up your own manifold if you want a better turbo. 3/8" flange and mandrel tubes would be great start.
Reply #4May 08, 2014, 09:23:11 pm
Diesel_Zuk
  • 182
« Reply #4 on: May 08, 2014, 09:23:11 pm »
I don't need anything special, and I'm needing it ASAP to get my samurai driving again. I bought an aaz manifold.
Reply #5May 09, 2014, 04:52:46 am
« Reply #5 on: May 09, 2014, 04:52:46 am »
that is what I am meaning. Get some tubes from your local exhaust shop and some plate from anywhere. You could have the manifold done tonight, faster than shipping and mate it to any turbo you wanted.
Reply #6May 09, 2014, 04:25:54 pm
Syncroincity
  • 727
Re:
« Reply #6 on: May 09, 2014, 04:25:54 pm »
Do you have any pictures of the setup?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #7May 09, 2014, 06:29:49 pm
Re:
« Reply #7 on: May 09, 2014, 06:29:49 pm »
Yeah, take a look through my build thread in the TDI section, there's quite a few in there.
