Author Topic: Location of engine code?  (Read 3582 times)
March 20, 2006, 04:32:00 pm
mnoll406
  • 26
« on: March 20, 2006, 04:32:00 pm »
Hey everybody,
I know this is a basic question, but where is the engine code on MK1 diesels. I'm going to hunt for a 81 or newer 1.6NA for my turbo project. Just want to make sure I don't grab a pre '81 block somebody stuffed into a newer car. Thanks for the help,
                                              Mike
Reply #1March 20, 2006, 04:51:15 pm
hillfolk'r
  • 1532
« Reply #1 on: March 20, 2006, 04:51:15 pm »
um,same place as an a2,,,,or its below,and to the right ofwhere the notches  are on the head gasket,,if you still see that part of the gasket,,,,,,below front water outlet on head,,on the block,,,in the # 3 cylinder area,,hope that will explain better,,,bring some sandpaper,and maybe a wire brush to read it,and then you only really need the first 2 letters
Throttle cables ftw
Reply #2March 20, 2006, 10:48:28 pm
mnoll406
  • 26
« Reply #2 on: March 20, 2006, 10:48:28 pm »
Thanks hillfolk'r. I thought it was there, but I couldn't make out anything on my engine will clean it off and take a look.
                                                        Mike
Reply #3April 19, 2006, 05:14:33 am
Katmandu
  • 47
« Reply #3 on: April 19, 2006, 05:14:33 am »
Quote from: "hillfolk'r"
Anyone have a listing of the Engine Codes ??
 How does one differentiate between a 1.5 and a 1.6 blocks and heads ??
Reply #4April 19, 2006, 09:51:03 pm
fspGTD
  • 1529
« Reply #4 on: April 19, 2006, 09:51:03 pm »
Moved to General.  Not IDI engine / power enhancement related.
Jake Russell
