Author Topic: 130 BAR SINGLE STAGE INJECTORS IN AAZ?  (Read 2143 times)
April 20, 2014, 08:25:20 pm
tdihuntdawg
  • 27
« on: April 20, 2014, 08:25:20 pm »
would 1y single stage injectors 130 bar work in a veteran mostly stock AAZ. Thanks in advance GLEANERDAWG
Reply #1April 20, 2014, 08:27:36 pm
Re:
« Reply #1 on: April 20, 2014, 08:27:36 pm »
They will "work" in that you will have a running engine. The injection lines are too long so they will need to be bent. The original AAZ injectors were 2-stage so they run quite a bit quieter than the older single stage ones.
Reply #2April 21, 2014, 03:30:54 am
Mark(The Miser)UK
  • 1557
Re: 130 BAR SINGLE STAGE INJECTORS IN AAZ?
« Reply #2 on: April 21, 2014, 03:30:54 am »
Yep will work, and later single stage nozzles were generally quieter than early ones, due to their modified tips, simulating 2 stage to some extent.
 Set timing lower than standard initially and adjust to taste. ;D
Mark-The-Miser-UK
