Author Topic: mk4 pully, hub set on rover pump  (Read 4275 times)
April 09, 2014, 05:25:12 am
« on: April 09, 2014, 05:25:12 am »
Mk4 hub, pully set on rover pump info
Well with current tdi m caddy project, a mk4 style hub and pully was used...
The interesting... Mk4 pump has timming mark behind hub for #1 and key way alignment... Also body has casting in it...
Rover pump has casting too... And a 2 digit number... Happens to be close nuff to call #1...
2nd interesting part... Those 3 bolts vw use hit pump body and prevent things from turning... Pay attention to this guys... I took belt off 3 times trying to figure out wtf... Stuff stopped turning by hand.... Sadly... Lines up with #4 ex valve going down like things trying to hit...
I need to get someone to build pump head to block brackets... I need to fab 3 and too point to make one to copy and get them machined... Under fuel lines to the pump bracket...
Reply #1April 09, 2014, 06:59:56 am
Re:
« Reply #1 on: April 09, 2014, 06:59:56 am »
I actually trimmed up a set of bolts to fit, I never had the original ones. Actually makes me happy to know they don't fit - I bought proper factory bolts for virtually everything else!
I would buy one of those brackets in a heartbeat if you make them. Dibs!
Reply #2May 27, 2014, 12:38:24 am
ToddA1
  • 434
Re: mk4 pully, hub set on rover pump
« Reply #2 on: May 27, 2014, 12:38:24 am »
What are the chances that you took pics of these?  The marks are for #1, not TDC?
-Todd
Reply #3May 27, 2014, 08:42:52 am
« Reply #3 on: May 27, 2014, 08:42:52 am »
Very good... Still no internet access to get from camera to web.... And 10gig limited sat service not acceptable to me... I have none vs $100/mo for that...
So may die with me....
Reply #4July 02, 2014, 06:52:38 am
« Reply #4 on: July 02, 2014, 06:52:38 am »
My pully i had made up
Split stock one, after holes machined in for plate, then split, slots added to plate for 3 teeth of adj incase i am tooth off on belt install...
Reply #5July 02, 2014, 09:23:31 pm
GEE-BEE
  • 1604
« Reply #5 on: July 02, 2014, 09:23:31 pm »
Thanx for the info..
 Iam sending out for a new alh sprocket and and ahu pump bracket to be machined before paowder coat of all the brackets from a long time vanagon hose customer..
Iam doing a G60 heads on both ahu builds
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
