Author Topic: Custom dash?  (Read 5326 times)
March 22, 2014, 11:31:36 pm
jaed_43725
Custom dash?
« on: March 22, 2014, 11:31:36 pm »
Has anyone or is it possible to make a custom dash for these cars? What I am thinking of is getting rid of the gauge cluster as it stands, having a piece of aluminum cut to size, whatever tabs I need put on, then gauge holes drilled. Then I run something like Autometer gauges, so I have a  tach on the outside up near the window, a speedo, oil pressure, water temp, boost and volts.
Reply #1March 23, 2014, 10:22:09 am
Re: Custom dash?
« Reply #1 on: March 23, 2014, 10:22:09 am »
Sure, knock yourself out, just cheaper you do it, more haggered it will look, so take your time
Reply #2March 23, 2014, 12:22:23 pm
jaed_43725
Re: Custom dash?
« Reply #2 on: March 23, 2014, 12:22:23 pm »
Are there any issues with the speedometer or tachometer? Do I have to hook them up some special way?
Reply #3March 23, 2014, 12:58:23 pm
  • Administrator
Re:
« Reply #3 on: March 23, 2014, 12:58:23 pm »
Speedo depends on the vehicle we are talking about. Guessing you have an earlier car with a cable driven speedo?
Tach needs a bit of special treatment. You will either need to get a Dakota Digital tach adapter to be able to read the signal from the W terminal on the alternator (factory style) or you will need to build your own triggering device for it based on something like a hall effect sensor. Since there is no ignition system the normal way of driving an electronic tach is not available.
Reply #4March 23, 2014, 01:34:40 pm
jaed_43725
Re: Custom dash?
« Reply #4 on: March 23, 2014, 01:34:40 pm »
Ok, that seems fairly easy for the tach. My car is an 85' so I am pretty sure its a cable driven speedo. Is there anything special I need to do about that?
Reply #5March 23, 2014, 01:49:55 pm
jaed_43725
Re: Custom dash?
« Reply #5 on: March 23, 2014, 01:49:55 pm »
I was looking at the Auto Meter diesel tach and it requires that I strap some stuff to the outside of the alternator and then use a scanning tool (scans a piece of tape on the flywheel) to dial it all in. Now with the Dakota Digital adapter can I use any tach?
Reply #6March 23, 2014, 02:21:59 pm
  • Administrator
Re:
« Reply #6 on: March 23, 2014, 02:21:59 pm »
Yup, with the Dakota adapter you can use any regular gasser tach you like.
Reply #7March 23, 2014, 05:02:53 pm
jaed_43725
Re: Custom dash?
« Reply #7 on: March 23, 2014, 05:02:53 pm »
Is there anything special I need to know about using say an Auto Meter speedometer?
Reply #8March 23, 2014, 05:36:41 pm
Re: Custom dash?
« Reply #8 on: March 23, 2014, 05:36:41 pm »
I prefer vdo vs chevy or ford parts... Temp sensors on vdo usually stock vw, they program speedo so can use vw electric for mk3 in mk1... Diesel tach hooks up like vw... Think you will get bent over with any and all onparts fuel gauge...
Just think abt those parts
Reply #9March 23, 2014, 08:39:42 pm
jaed_43725
Re: Custom dash?
« Reply #9 on: March 23, 2014, 08:39:42 pm »
I def was not going to use Chevy or Ford stuff. All aftermarket. I could really care less about the factory gauges. Also VDO costs a little more than Auto Meter, and I like Auto Meter. And my speedo as I said is mechanical. The fuel gauge is simple.
Reply #10March 25, 2014, 08:11:34 am
Re: Custom dash?
« Reply #10 on: March 25, 2014, 08:11:34 am »
Not trying to hate, but those use gm, ford, dodge style sensors, black wire groung wiring and such, how is it not gm, ford parts?vdo does not make aux fuel gauge to work our stock float units... You need to get its ohm reading and do serious reserch... Cause i doubt one exidts...
And consider me a dick, just being honest... Ill not bug this thread anymore
Reply #11March 26, 2014, 12:23:30 am
jaed_43725
Re: Custom dash?
« Reply #11 on: March 26, 2014, 12:23:30 am »
What he meant was using the gauges that came out of those vehicles, as in getting them from a junkyard. And then he said he likes VDO gauges. Well thats fine you can like whatever gauges you want. I like Auto Meter, so I will use them. You read way way way to far into the post.
Reply #12March 26, 2014, 09:05:24 am
  • 7834
Re: Custom dash?
« Reply #12 on: March 26, 2014, 09:05:24 am »
No, he is correct. He has seen my setup and I bought all new from summit. The senders are for US made cars, you have to drill and tap or adapt them. It is doable, but not fun and nothing matches the older interior.
Reply #13March 26, 2014, 12:30:13 pm
  • Administrator
Re: Custom dash?
« Reply #13 on: March 26, 2014, 12:30:13 pm »
What he said...
You need to replace all the senders pretty much as the stock senders are VDO-type and have the wrong range for most of the Autometer gauges.  Generally speaking the senders included with the Autometer gauges are going to be  1/8-27 NPT whereas VW uses M10 holes for oil pressure/temperature.  The stock VW temperature senders are usually clipped in to a plastic housing versus screwed in to a block coolant passage.  There are some Autometer fuel level gauges that are pretty close to the VW range (#4316 for instance) but those are only available in some series.
These are obviously all solve-able problems, but it takes more engineering than simply using VDO gauges which speak the same language as the senders already installed in the car.  No need to install new wiring that way, no need to engineer a solution for installing the senders, etc.
Reply #14March 29, 2014, 05:01:27 pm
  • 7834
Re: Custom dash?
« Reply #14 on: March 29, 2014, 05:01:27 pm »
What he said...
What he said...
and I and CRSMP5 said too. It is doable and if you like the design go for it. Just realize it isn't as simple as buying gauges and screwing them in.
Fixmyvw.com
