Author Topic: 1y ip to aaz ip  (Read 2343 times)
March 17, 2014, 03:25:17 pm
bbob203
  • 1789
1y ip to aaz ip
« on: March 17, 2014, 03:25:17 pm »
Could I put an aaz pump top onto a 1y pump without any modifications?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1March 17, 2014, 03:27:49 pm
Re: 1y ip to aaz ip
« Reply #1 on: March 17, 2014, 03:27:49 pm »
It's likely the exact same procedure as installing a LDA on a 1.6NA pump.
Reply #2March 18, 2014, 10:37:02 am
MJF
  • 581
Re: 1y ip to aaz ip
« Reply #2 on: March 18, 2014, 10:37:02 am »
1Y has 8mm plunger.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3March 18, 2014, 12:36:36 pm
Re: 1y ip to aaz ip
« Reply #3 on: March 18, 2014, 12:36:36 pm »
For that matter, why not just swap in the complete AAZ pump?
Reply #4March 18, 2014, 12:59:38 pm
bbob203
  • 1789
Re: 1y ip to aaz ip
« Reply #4 on: March 18, 2014, 12:59:38 pm »
I may still deciding if I want to go na or turbo with it. Would a 9mm pump be ok woth na? giles pump?
03 Jetta wagon TDi
Reply #5March 20, 2014, 03:44:27 pm
Re: 1y ip to aaz ip
« Reply #5 on: March 20, 2014, 03:44:27 pm »
9mm would be fine. It's what came on 1.6NAs so you don't have to worry about overfuelling.
You can't go wrong with a Giles pump. The one my brother has on his 1.9NA is great.
