Author Topic: 1.5 starting issue  (Read 2832 times)
March 09, 2014, 05:04:16 pm
sk8ordie
  • 20
1.5 starting issue
« on: March 09, 2014, 05:04:16 pm »
My 80 rabbit runs perfect if I pop start it. It will not however, start using the key. You can crank it forever, and it acts like a diesel getting no fuel (yes it's getting fuel). By that I mean, no combustion, rumbling, smoke, etc. just cranks.
Wtf m8?
Thanks
Reply #1March 09, 2014, 05:19:56 pm
Re: 1.5 starting issue
« Reply #1 on: March 09, 2014, 05:19:56 pm »
Low compression, methinks. Got blowby when running?
Reply #2March 09, 2014, 05:24:50 pm
« Reply #2 on: March 09, 2014, 05:24:50 pm »
power at shutoff solenoid while cranking?
Reply #3March 09, 2014, 06:08:18 pm
sk8ordie
  • 20
« Reply #3 on: March 09, 2014, 06:08:18 pm »
Blow by not so much. She rips for a 1.5 also - Burt dyno analysis.
Interesting. Could I test this by simply unplugging the shutoff solenoid?
Reply #4March 09, 2014, 06:36:00 pm
« Reply #4 on: March 09, 2014, 06:36:00 pm »
No, you need a volt meter or test light.
Reply #5March 10, 2014, 06:17:24 am
Gizmoman
  • 1301
« Reply #5 on: March 10, 2014, 06:17:24 am »
^^ and someone to turn the key while you look for 12 volts to the solenoid (while it cranks). ;)
Reply #6March 10, 2014, 12:05:39 pm
« Reply #6 on: March 10, 2014, 12:05:39 pm »
I just set the meter against the raised up hood and run the leads out to the points of contact and clip them where they need to be.  But I do have a good selection of jumpers with alligator clips on them.
