Author Topic: Boost on 91 jetta how much i can pump it too  (Read 3337 times)
March 19, 2006, 07:16:09 am
xtrigger
  • 48
    d3lahk
« on: March 19, 2006, 07:16:09 am »
I have a 91 turbo diesel jetta and im wondering how much Boost the engine can take before it destroys it self...thx
mods im thinkin of are
intercooler
boost controller (if i can)
fix the oil blow by problem it has (oil in intaje, turbo everywere)
thanks again
1986 VW Jetta TDI
Reply #1March 19, 2006, 08:11:58 am
SMOKEYDUB
  • 630
« Reply #1 on: March 19, 2006, 08:11:58 am »
35 i believe then it lifts the head off the block :lol:  so maybe run 32?
jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2March 19, 2006, 08:19:02 am
xtrigger
  • 48
    d3lahk
« Reply #2 on: March 19, 2006, 08:19:02 am »
Thx lol i think ill go with 20psi if i can get the dam tubro to build boost...
1986 VW Jetta TDI
Reply #3March 19, 2006, 08:39:16 am
wyldman
  • 403
« Reply #3 on: March 19, 2006, 08:39:16 am »
Boost is not just a number you pick out of your head,or try to get as much as possible.
You need fuel first,to go with the boost,and make it in the first place.
You only need enough air to burn the fuel you have,or it's a waste.
A turbo must be within it's efficiency map,or your not doing any good,no matter how much boost your running.It's not all about pressure.
(416)565-7282
Reply #4March 19, 2006, 09:52:29 am
hillfolk'r
  • 1532
« Reply #4 on: March 19, 2006, 09:52:29 am »
i have a manual boost controller,and ill let it go closed wastegate,,the idi's  will lift somewhere in30-35 psi,,,,thats why i built a tdi,,or get a metalheadgasket+studs,,get studs anyways,,,,i popped 3 or 4 gaskets inmy 84 1.6td,closed wastegate would go about 35,,,but it seemed to pop emmore when ireally cranked up the fuel,,,,,hah ask rabbittree when he drove my car,,we went for a ride,,i told him tobeat it like a stepchild,,well rollinabout 75 or so in it hard,,and the loudest bang you ever heard,,when we pulled over,,the head gasket blew out on 3 sides on number 4 cyl,,yea it wasnt even under the block anymore,itwas funny,,,,but thats a 12mm pump,and closed wastegate,no ic either,,but it ran good,,,,i could tellwhenthe head was lifting,,the water tempwould rise rapidly,and lotsa pressure inthe cooling system,,,,,,ive had them leakafter driving hard,then"reseal" when cold,and with not lots of boost,,be okfor a while,,,,,,,
Throttle cables ftw
Reply #5April 12, 2006, 12:55:54 pm
fspGTD
  • 1529
« Reply #5 on: April 12, 2006, 12:55:54 pm »
Moved to IDI Diesel power enhancement section
Jake Russell
