Author Topic: Plastic intercooler/intake pipes  (Read 3217 times)
February 26, 2014, 07:52:39 am
rodpaslow
  • 670
« on: February 26, 2014, 07:52:39 am »
How much boost will the standard plastic pipes take?  Does the intercooler survive at 20 psi? (I think standard is supposed to be 8 max)
Reply #1February 26, 2014, 09:17:59 am
jboogie13
  • 175
Re: Plastic intercooler/intake pipes
« Reply #1 on: February 26, 2014, 09:17:59 am »
which model are you talking about? My stock ALH piping/IC is still holding at 22psi. I would think the AHU/1z to be the same.
Reply #2February 26, 2014, 10:26:43 am
rodpaslow
  • 670
« Reply #2 on: February 26, 2014, 10:26:43 am »
Yeah, the one I have is a 1Z out of a passat.  Just wondering.  I have a intercooler that is welded aluminum, just wondering if  I should plan on upgrading the plastic tubing as well.
Reply #3February 26, 2014, 01:46:42 pm
RobertMcC
  • 28
« Reply #3 on: February 26, 2014, 01:46:42 pm »
My old 1Z stock setup used to spike 24PSI if the pipes didn't burst then. I think you be fine. They run stock about 12 PSI.
2001 Jetta TDI ( 216, CX racing FMIC )
