Author Topic: Late style AAZ pump bracket w/ rover pump  (Read 3205 times)
January 30, 2014, 12:25:32 pm
bbob203
  • 1789
« on: January 30, 2014, 12:25:32 pm »
Instead of getting and ahu bracket machined etc can one use the bracket from the aaz with the alh style pulley?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1January 30, 2014, 12:37:24 pm
Re: Late style AAZ pump bracket w/ rover pump
« Reply #1 on: January 30, 2014, 12:37:24 pm »
Well, yes, sorta.  It will work, but is lacking the extra roller between the pump and cam.  While it would likely work just fine, I'd be a little leery.  VW added that roller with the switch to the larger 10mm pump head and the Rover is 11mm.  I'd personally prefer having the extra degrees of engagement.
Reply #2January 30, 2014, 12:45:23 pm
bbob203
  • 1789
« Reply #2 on: January 30, 2014, 12:45:23 pm »
Ah yes having somebody bore it out vs welding and fabrication. I'll just pay someone a few shillings to bore it.
03 Jetta wagon TDi
Reply #3January 30, 2014, 01:13:39 pm
« Reply #3 on: January 30, 2014, 01:13:39 pm »
Do you have a project in the works?
Reply #4January 30, 2014, 01:35:22 pm
bbob203
  • 1789
« Reply #4 on: January 30, 2014, 01:35:22 pm »
I'm helping my friend with an ahu swap into a eurovan weekender and he opted for the 11mm alh pump. Promted me to find out if anyone had ever tried that configuration.
03 Jetta wagon TDi
