VWDiesel Blog
Facebook Group
VWD on Twitter
TDI Engine -General Info
Ford Transit 2.5 Injection Pump on ALH
Topic: Ford Transit 2.5 Injection Pump on ALH (Read 13068 times)
January 25, 2014, 10:10:06 am
January 25, 2014, 10:10:06 am »
Has anyone run one? A friend of mine sent me this pic of an engine he purchased. He didn't see it run but the specs look good. 11mm plunger, the 20mm mainshaft rotates the correct direction, the sprocket offset is correct and the snout mounting hole is the same as the ALH. The accelerator lever rotates the opposite direction of the VW mechanical pumps, but the ALH has the pump mounted far enough away from the engine that it wouldn't be an issue.
January 25, 2014, 11:11:21 am
Administrator
Re:
January 25, 2014, 11:11:21 am »
Can't say I've seen one on a VW in any of the research I did looking for my pump. Someone will need to guinea pig!
January 25, 2014, 12:37:49 pm
Re: Ford Transit 2.5 Injection Pump on ALH
January 25, 2014, 12:37:49 pm »
I think the UK guy getting rover pumps over here has done some experimenting. He will not join this place though
http://www.vwdiesel.net/forum/index.php?topic=16572.0
Round 2
http://www.vwdiesel.net/forum/index.php?topic=31758.0
January 28, 2014, 12:04:45 pm
wisconsinjohnson
User+
January 28, 2014, 12:04:45 pm »
I just talked to owner, you may have your guinea pig. Checking it out tomorrow, sounds like no one has tried to start it.
January 28, 2014, 06:43:06 pm
Administrator
Re:
January 28, 2014, 06:43:06 pm »
Sweet! Keep us posted. More options for mtdi!
January 30, 2014, 11:56:28 pm
Sillycaddy
User+
January 30, 2014, 11:56:28 pm »
Did you pick it up? I noticed the CL ad was taken down.
January 31, 2014, 09:22:45 am
rbremiller
January 31, 2014, 09:22:45 am »
In a quick ebay search for this pump, I found 6 different pump#'s to choose from.
Ford Transit 2.5 Diesel 0460414146
Transit 2.5DI pump: 0 460 414 052
Ford Transit 2.5 DI Bosch: 0460414153
Ford Transit FT 150 2.5 DI Bosch: 0460414152
FORD TRANSIT 2,5DI 51KW Motor:4FB 0460414123
FORD Transit IV und V 2.5 DI 56 KW 76 PS 0460414119
They appear to have the same specs/internals as a Rover pump; DI, 11mm and 4000rpm gov. Throttle levers are reversed. They are very plentiful and cheap.
'91 180k Audi 80Q mTDI DD AHU, K14, LT pump,
http://www.motorgeek.com/viewtopic.php?t=45645
'99 Jetta TDI 204k '02 engine, RC3+E, 11mm IP, .216, Racepipe, 2.5''SS exhaust, PD Lift pump, Boostvalve, PanzerPlate, boost gauge, MAF delete.
'89 Audi 80Q ...waiting
'85 BMW R80
January 31, 2014, 08:00:42 pm
snakemaster
January 31, 2014, 08:00:42 pm »
i have done a few .its very close to the LR pump , i lift the lid and snap of the steel part that restriks the control lever , so it gets more travel , sort of a LDA but for a non turbo , its a bit like a 1.9 td eco pump but a 2.5di one , the LDA parts dont fit in the lda looking thing on the ford transit pump .
Glenmorangie single highland malt
February 01, 2014, 06:48:31 pm
February 01, 2014, 06:48:31 pm »
Thanks for the info, Snakemaster. I didn't realize that it didn't have a functional LDA. Bummer.
June 18, 2019, 11:29:06 am
Dino
User+
June 18, 2019, 11:29:06 am »
Hello.
That's the 0 460 414 052 pump.
REPLACING PARTS:
ORDER NUMBER DESIGNATION CODE POSITION QUANTITY
2 460 283 001 SHAFT SEALING RING 2460283001 3 1
1 467 030 308 SUPPLY PUMP 1467030308 7 1
1 467 030 303 SUPPLY PUMP 1467030303 7 1
1 460 134 317 SUPPORT RING 1460134317 9 1
1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2
1 466 100 390 DRIVE SHAFT 1466100390 12 1
1 460 023 302 WOODRUFF KEY 1460023302 13 1
1 460 056 302 BUFFER 1460056302 15 2
1 466 317 301 TOOTHED GEAR 1466317301 16 1
2 460 102 001 SLIDING DISK 2460102001 17 1
1 460 232 327 ROLLER RING 1460232327 20 1
1 463 100 307 BEARING PIN 1463100307 21 4
2 460 300 005 ROLLER 2460300005 22 4
2 460 120 013 FRICTION WASHER 2460120013 23 4
1 463 103 315 ADJUSTING PIN 1463103315 24 1
1 463 120 359 RETAINING PIN 1463120359 25 1
1 461 310 300 RETAINING BRACKET 1461310300 26 1
1 460 140 334 CROSS DISK 1460140334 27 1
1 466 110 619 CAM PLATE 1466110619 29 1
2 460 223 001 SEAL RING 2460223001 30 1
1 463 104 469 TIMING-DEVICE PISTON 1463104469 31 1
1 463 218 312 SLIDING PIECE 1463218312 32 1
1 460 100 902 SELECTION GROUP SHIM RING 1460100902 33 2
1 464 619 734 COMPRESSION SPRING, 36,30 MM 1464619734 34 1
1 464 619 628 COMPRESSION SPRING, 36,50 MM 1464619628 34 1
1 464 619 619 COMPRESSION SPRING, 36,70 MM 1464619619 34 1
1 460 100 902 SELECTION GROUP SHIM RING 1460100902 35 1
2 460 223 001 SEAL RING 2460223001 36 1
1 465 530 301 CLOSING COVER 1465530301 37 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2
1 461 074 312 COVER PLATE 1461074312 39 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 40 2
1 468 334 487 HYDRAULIC HEAD 1468334487 50 1
2 460 210 012 O-RING 2460210012 51 1
SELECTION GROUP SHIM 52 1
1 460 105 305 GASKET 1460105305 54 4
FITTING 58 4
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2
1 460 210 008 O-RING 1460210008 66 1
1 467 134 815 HYDRAULIC STOP 1467134815 67 1
1 463 161 835 PART LOAD GOVERNOR 1463161835 68 1
1 200 101 640 SHIM 1200101640 69 1
1 461 900 496 CONTROL LEVER 1461900496 72 1
1 463 315 310 FLANGE NUT 1463315310 75 1
ADJUSTING SCREW 88 1
1 461 015 302 GASKET 1461015302 92 1
1 461 907 810 FULCRUM LEVER 1461907810 95 1
2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1
1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2
1 460 105 307 GASKET 1460105307 105 2
1 464 613 611 COMPRESSION SPRING 1464613611 106 2
1 463 300 304 HEXAGON NUT 1463300304 107 1
1 463 590 311 GOVERNOR SHAFT 1463590311 108 1
1 460 210 313 O-RING 1460210313 109 1
1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1
SELECTION GROUP SUPPORTING DISK 111 1
1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1
1 460 100 370 SHIM RING 1460100370 114 1
1 460 422 305 SLIDING SLEEVE 1460422305 115 1
1 461 290 301 LOCKING PLATE 1461290301 116 1
1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1
2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4
1 460 210 349 O-RING 1460210349 129 1
1 463 461 306 SCREW PLUG 1463461306 130 1
1 460 105 306 FLAT SEAL RING 1460105306 131 1
1 463 453 306 BLEEDER SCREW 1463453306 132 1
1 460 225 081 O-RING 1460225081 133 1
1 460 225 082 O-RING 1460225082 134 1
1 460 362 419 CONTROL VALVE 1460362419 135 1
1 463 456 358 HOLLOW BOLT 1463456358 136 1
1 460 591 315 PROTECTIVE CAP 1460591315 140 1
2 410 508 006 PROTECTIVE CAP 2410508006 141 1
2 464 633 002 COMPRESSION SPRING 2464633002 200 1
1 461 314 301 DISTANCE PIECE 1461314301 202 1
1 463 300 316 HEXAGON NUT 1463300316 206 1
2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1
1 464 651 452 COILED SPRING 1464651452 220 1
1 467 230 360 CONTROL UNIT 1467230360 235 1
1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2
0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1
1 464 477 302 BLADE TERMINAL 1464477302 242 1
1 463 314 306 FLANGE NUT 1463314306 243 1
1 460 105 312 FLAT SEAL RING 1460105312 251 1
2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2
1 466 434 309 COUPLING HALF 1466434309 270 1
2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1
2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2
2 460 223 001 SEAL RING 2460223001 277 1
2 410 508 006 PROTECTIVE CAP 2410508006 285 1
1 461 900 514 CONTROL LEVER 1461900514 289 1
1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1
1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1
1 460 342 311 INTERMEDIATE PIECE 1460342311 295 1
1 463 412 301 CHEESE HEAD SCREW 1463412301 296 1
1 463 305 305 CLAMPING PIECE 1463305305 297 1
1 463 450 308 BREAK-OFF SCREW 1463450308 307 2
1 460 522 328 SPRING SEAT 1460522328 325 1
1 460 522 304 SPRING SEAT 1460522304 329 1
2 911 222 700 HOLLOW BOLT 2911222700 353 1
2 911 222 700 HOLLOW BOLT 2911222700 357 1
1 460 105 313 FLAT SEAL RING 1460105313 358 2
1 460 105 313 FLAT SEAL RING 1460105313 364 2
1 460 793 350 CONNECTING PIPE 1460793350 365 1
1 460 101 620 SHIM 1460101620 380 1
1 465 530 857 FITTING COVER 1465530857 381 1
1 461 933 344 CONTROL LEVER 1461933344 382 1
1 461 933 341 CONTROL LEVER 1461933341 382 1
1 461 331 331 STOP BRACKET 1461331331 383 1
1 464 651 433 COILED SPRING 1464651433 384 1
2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1
2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1
1 461 901 483 CONTROL LEVER 1461901483 388 1
1 460 300 318 SPACER BUSHING 1460300318 389 1
2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 1
1 460 210 322 O-RING 1460210322 392 1
1 463 414 306 LOCKING SCREW 1463414306 393 1
1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1
2 423 450 002 BREAK-OFF SCREW 2423450002 418 2
2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1
1 461 329 339 MOUNTING BRACKET 1461329339 492 1
1 463 126 333 SPHERICAL BOLT 1463126333 496 1
1 463 314 309 FLANGE NUT 1463314309 499 1
1 463 315 307 HEXAGON NUT 1463315307 580 2
1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1
1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1
1 460 591 313 SEALING CAP, RED 1460591313 808 1
2 420 580 005 SEALING CAP, RED 2420580005 809 1
Unfortunately I can't do any attachment to make it appears as on the web page I found it.
I'll look for the other pumps.
0 460 414 119
REPLACING PARTS:
1 460 232 328 ROLLER RING 1460232328 20 1
2 463 100 002 BEARING PIN 2463100002 21 4
1 463 103 316 ADJUSTING PIN 1463103316 24 1
1 460 140 334 CROSS DISK 1 460 140 334 27 1
1 466 110 653 CAM PLATE 1466110653 29 1
1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1
1 460 144 302 SHIM RING 1460144302 33 1
1 464 618 934 COMPRESSION SPRING 1464618934 34 1
1 460 100 178 PLAIN WASHER 1460100178 35 1
1 465 530 901 CLOSING COVER 1465530901 37 1
1 461 074 330 COVER PLATE 1461074330 39 1
2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2
1 468 334 859 HYDRAULIC HEAD 1468334859 50 1
2 463 370 021 FITTING 2463370021 58 4
1 460 210 008 O-RING 1460210008 66 2
1 467 135 997 HYDRAULIC STOP 1467135997 67 1
1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1
1 461 900 613 CONTROL LEVER 1461900613 72 1
1 461 907 803 FULCRUM LEVER 1461907803 95 1
1 460 422 324 SLIDING SLEEVE 1460422324 115 1
1 460 508 309 SEALING CAP 1460508309 116 1
2 463 461 002 SCREW PLUG 2463461002 130 1
2 463 461 001 BLEEDER SCREW 2463461001 132 1
1 460 362 456 CONTROL VALVE 1460362456 135 1
1 463 456 360 HOLLOW BOLT 1463456360 136 1
1 461 314 322 DISTANCE PIECE 1461314322 202 1
1 461 021 621 SUPPORT PLATE 1461021621 235 1
1 466 434 324 COUPLING HALF 1466434324 270 1
1 461 900 616 CONTROL LEVER 1461900616 289 1
1 461 900 615 CONTROL LEVER 1461900615 289 1
1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1
1 460 100 893 PLAIN WASHER 1460100893 346 1
1 460 793 379 CONNECTING PIPE 1460793379 365 1
1 461 335 346 CONTROL LEVER 1461335346 388 1
1 460 100 199 SPACER RING 1460100199 389 1
2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2
1 463 300 320 HEXAGON NUT 1463300320 422 1
SELECTION GROUP SHIM 452 3
1 464 616 340 COMPRESSION SPRING 1464616340 453 1
1 463 219 304 CONTROL SPOOL 1463219304 455 1
1 460 505 308 CLOSURE CAP 1460505308 471 1
2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1
1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1
1 465 134 990 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134990 800 1
0 460 414 123
REPLACING PARTS:
1 467 135 996 HYDRAULIC STOP 1467135996 67 1
1 461 903 310 CONTROL LEVER 1461903310 388 1
1 464 616 998 COMPRESSION SPRING 1464616998 453 1
1 464 616 955 COMPRESSION SPRING 1464616955 453 1
1 464 616 344 COMPRESSION SPRING 1464616344 453 1
I found them on danmax.ee
Last Edit: June 18, 2019, 11:49:36 am by Dino
June 18, 2019, 11:50:44 am
Dino
User+
June 18, 2019, 11:50:44 am »
0 460 414 146
REPLACING PARTS:
1 461 074 328 SEALING PLATE 1461074328 30 1
1 463 104 667 TIMING-DEVICE PISTON 1463104667 31 1
1 461 038 319 SEALING PLATE 1461038319 36 1
2 461 038 019 COVER PLATE 2461038019 39 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 40 4
1 463 414 361 MICROENCAPSULATED SCREW, MICO 1463414361 60 2
1 467 135 999 HYDRAULIC STOP 1467135999 67 1
F 002 D11 460 GOVERNOR SHAFT, MICO F002D11460 108 1
1 463 414 362 MICROENCAPSULATED SCREW, MICO 1463414362 237 2
0 330 001 041 PUSHING ELECTROMAGNET 0330001041 240 1
2 410 508 006 PROTECTIVE CAP 2410508006 285 2
F 002 D11 455 HOLLOW BOLT, MICO F002D11455 353 1
F 002 D11 455 HOLLOW BOLT, MICO F002D11455 357 1
1 465 134 967 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134967 800 1
0 460 414 152
REPLACING PARTS:
0 281 005 025 SOLENOID-VALVE CONTROL UN 0281005025 184 1
1 464 651 460 COILED SPRING 1464651460 220 1
1 461 021 889 SUPPORT PLATE 1461021889 235 1
2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 3
1 467 010 556 PARTS SET THEFT PROTECTION 1467010556 825 1
0 460 414 153
REPLACING PARTS:
1 466 110 639 CAM PLATE 1466110639 29 1
1 464 616 963 COMPRESSION SPRING 1464616963 453 1
News of the engine and the injection pump?
Unfortunately the engine picture is missing and I don't know the pump code.
I hope there isn't any piece of mistake about datas and that they can be useful.
The application list is missing,there's a long VE pump list on that site and it seems that those pump are capable of 4000rpms as it was already said.
Last Edit: June 18, 2019, 12:17:39 pm by Dino
Reply #11
June 18, 2019, 01:25:28 pm
Dino
User+
Reply #11 on:
June 18, 2019, 01:25:28 pm »
Hello.
There are other Ford Transit injection pumps.
Mark Type Part number Applications Photo Engine
bosch VE 0460404005 VE R 14/1 Ford Transit 100/190 46 kw York
bosch VE 0460414073 VE R 366 Ford Transit 2.5D 52 kw 4 AB, 4 CA Enquiries
bosch VE 0460414083 VE R 415 Ford Transit 2.5 DI 59 kw 4 DA
bosch VE 0460414108 VE R 567 Ford Transit 2.5 D 56 kw 4 HA, 4 HB, 4 FA, 4 FC
bosch VE 0460414113 VE R 567/1 Ford Transit 2.5 D 51 kw 4 FA, 4 FB, 4 FC
bosch VE 0460414119 VE R 624 Ford Transit, Tourneo 51-56 kw 4 FB, 4HB, 4HC …
bosch VE 0460414146 VE R 686/3 Ford Transit 2.5 D 56 kw 4 HB, 4 HC KAT
bosch VE 0460414150 VE R 624/4 Ford Transit 2.5 D 56 kw 4 FA, 4 FB, 4 FC 4 HB, 4 HC
I think there is something strange,Tourneo. What is it?
The pumps must be for old vans.
Maybe the first of the list is for an IDI engine.
By looking at the engine power I can't understand if they are all N/A engine or the turbos add just some hp.
The parts list of all those pump is avaiable too.
0 460 414 073
REPLACING PARTS:
FITTING 58 4
1 467 134 823 HYDRAULIC STOP 1467134823 67 1
1 463 162 063 PART LOAD GOVERNOR 1463162063 68 1
1 461 900 564 CONTROL LEVER 1461900564 72 1
1 461 900 566 CONTROL LEVER 1461900566 289 1
1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 2
1 461 933 363 CONTROL LEVER 1461933363 382 1
1 461 933 362 CONTROL LEVER 1461933362 382 1
1 461 903 304 CONTROL LEVER 1461903304 388 1
1 460 200 339 SPACER RING 1460200339 389 2
0 460 414 083
REPLACING PARTS:
1 468 334 580 HYDRAULIC HEAD 1468334580 50 1
1 467 134 842 HYDRAULIC STOP 1467134842 67 1
1 461 900 639 CONTROL LEVER 1461900639 72 1
1 461 907 808 FULCRUM LEVER 1461907808 95 1
1 464 616 956 COMPRESSION SPRING 1464616956 453 1
Last Edit: June 21, 2019, 01:03:17 pm by Dino
Reply #12
June 21, 2019, 01:13:03 pm
Dino
User+
Reply #12 on:
June 21, 2019, 01:13:03 pm »
Hello.
0 460 414 108
REPLACING PARTS:
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 1
1 467 134 840 HYDRAULIC STOP 1467134840 67 1
1 467 230 404 CONTROL UNIT 1467230404 235 1
1 463 414 305 TORX FILLISTER SCREW 1463414305 237 3
1 460 300 312 SPACER BUSHING 1460300312 248 1
1 460 591 318 HOOD 1460591318 720 1
0 460 414 113
REPLACING PARTS:
1 467 134 843 HYDRAULIC STOP 1467134843 67 1
0 460 414 150
REPLACING PARTS:
F 002 D11 347 PUSHING ELECTROMAGNET F002D11347 240 1
0460414073 VE4/11F2000R366
0460414083 VE4/11F2000R415
0460414108 VE4/11F2000R567
0460414113 VE4/11F2000R567-1
0460414119 VE4/11F2000R624
0460414123 VE4/11F2000R624-1
0460414146 VE4/11F2000R686-3
0460414150 VE4/11F2000R624-4
0460414152 VE4/11F2000R624-6
0460414153 VE4/11F2000R624-7
Reply #13
August 03, 2019, 01:03:51 pm
Dino
User+
Reply #13 on:
August 03, 2019, 01:03:51 pm »
Hello.
Another Ford Transit pump.
0460414085 VE4/11F2000R415-1
REPLACING PARTS:
1 460 140 337 CROSS DISK 1460140337 27 1
1 461 335 348 CONTROL LEVER 1461335348 388 1
1 463 126 333 SPHERICAL BOLT 1463126333 500 1
1 463 314 309 FLANGE NUT 1463314309 503 1
There's another Ford injection pump with the same camplate,it's used on Ford Ranger 2.5. Is it a rebagded Mazda pick up?
That's the same camplate used for Croma 0460414096 and 0460414125 injection pumps.
According the 2009-2010 catalogue the same camplate was used for an industrial engine too. The list isn't complete,for exemple Croma pumps are missing.
On web there are other 2000rpms pumps but the application list is missing,they can be for Transit,Land Rover or other engines.
I thought that I can add the pumps with the same number after R and the"-".
Camplate 1 466 110 619:0460414083,0460414085,0460414200(Ford Ranger),0460424082,0460424091.
Other pumps with the same number after the R.
0460414089 VE4/11F2000R415-2
0460414107 VE4/11F2000R415-3
0460414138 VE4/11F2000R624-2
0460414139 VE4/11F2000R624-3
0460414151 VE4/11F2000R624-5
0460414208 VE4/11F2000R686-4
0 460 414 089
REPLACING PARTS:
1 467 134 835 HYDRAULIC STOP 1467134835 67 1
It seems that there is the ADA on those pumps.
Last Edit: August 03, 2019, 02:17:48 pm by Dino
Reply #14
August 03, 2019, 02:22:11 pm
Dino
User+
Reply #14 on:
August 03, 2019, 02:22:11 pm »
0 460 414 107
REPLACING PARTS:
1 467 134 830 HYDRAULIC STOP 1467134830 67 1
1 464 616 334 COMPRESSION SPRING 1464616334 453 1
1 463 315 307 HEXAGON NUT 1463315307 580 1
0 460 414 138
REPLACING PARTS:
0 460 414 139
REPLACING PARTS:
