VWDiesel Blog
Facebook Group
VWD on Twitter
TDI Engine -General Info
Ford Transit 2.5 Injection Pump on ALH
Pages:
Topic: Ford Transit 2.5 Injection Pump on ALH (Read 12289 times)
Reply #15
August 03, 2019, 02:25:03 pm
Dino
User+
Re: Ford Transit 2.5 Injection Pump on ALH
Reply #15 on:
August 03, 2019, 02:25:03 pm »
0 460 414 151
REPLACING PARTS:
ORDER NUMBER DESIGNATION CODE POSITION QUANTITY
2 460 283 001 SHAFT SEALING RING 2460283001 3 1
1 467 030 308 SUPPLY PUMP 1467030308 7 1
1 467 030 303 SUPPLY PUMP 1467030303 7 1
1 460 134 317 SUPPORT RING 1460134317 9 1
1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2
1 466 100 390 DRIVE SHAFT 1466100390 12 1
1 460 023 302 WOODRUFF KEY 1460023302 13 1
1 460 056 302 BUFFER 1460056302 15 2
1 466 317 301 TOOTHED GEAR 1466317301 16 1
2 460 102 001 SLIDING DISK 2460102001 17 1
1 460 232 328 ROLLER RING 1460232328 20 1
2 463 100 002 BEARING PIN 2463100002 21 4
2 460 300 005 ROLLER 2460300005 22 4
2 460 120 013 FRICTION WASHER 2460120013 23 4
1 463 103 316 ADJUSTING PIN 1463103316 24 1
1 463 120 359 RETAINING PIN 1463120359 25 1
1 461 310 300 RETAINING BRACKET 1461310300 26 1
1 460 140 334 CROSS DISK 1460140334 27 1
1 466 110 619 CAM PLATE 1466110619 29 1
1 461 074 328 SEALING PLATE 1461074328 30 1
1 463 104 667 TIMING-DEVICE PISTON 1463104667 31 1
1 463 218 312 SLIDING PIECE 1463218312 32 1
1 460 144 302 SHIM RING 1460144302 33 1
1 464 618 934 COMPRESSION SPRING 1464618934 34 1
1 460 100 178 PLAIN WASHER 1460100178 35 1
1 461 038 319 SEALING PLATE 1461038319 36 1
1 465 530 901 CLOSING COVER 1465530901 37 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2
2 461 038 019 COVER PLATE 2461038019 39 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 40 4
1 468 334 859 HYDRAULIC HEAD 1468334859 50 1
2 460 210 012 O-RING 2460210012 51 1
SELECTION GROUP SHIM 52 1
1 460 105 305 GASKET 1460105305 54 4
2 463 370 021 FITTING 2463370021 58 4
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2
1 460 210 008 O-RING 1460210008 66 2
1 467 135 996 HYDRAULIC STOP 1467135996 67 1
1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1
1 200 101 640 SHIM 1200101640 69 1
1 461 900 613 CONTROL LEVER 1461900613 72 1
1 463 315 310 FLANGE NUT 1463315310 75 1
ADJUSTING SCREW 88 1
1 461 015 302 GASKET 1461015302 92 1
1 461 907 803 FULCRUM LEVER 1461907803 95 1
2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1
1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2
1 460 105 307 GASKET 1460105307 105 2
1 464 613 611 COMPRESSION SPRING 1464613611 106 2
1 463 300 304 HEXAGON NUT 1463300304 107 1
1 463 590 311 GOVERNOR SHAFT 1463590311 108 1
1 460 210 313 O-RING 1460210313 109 1
1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1
SELECTION GROUP SUPPORTING DISK 111 1
1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1
1 460 100 370 SHIM RING 1460100370 114 1
1 460 422 324 SLIDING SLEEVE 1460422324 115 1
1 460 508 309 SEALING CAP 1460508309 116 1
1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1
2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4
1 460 210 349 O-RING 1460210349 129 1
1 463 461 306 SCREW PLUG 1463461306 130 1
1 460 105 306 FLAT SEAL RING 1460105306 131 1
1 463 453 306 BLEEDER SCREW 1463453306 132 1
1 460 225 081 O-RING 1460225081 133 1
1 460 225 082 O-RING 1460225082 134 1
1 460 362 456 CONTROL VALVE 1460362456 135 1
1 463 456 360 HOLLOW BOLT 1463456360 136 1
1 460 591 315 PROTECTIVE CAP 1460591315 140 1
2 410 508 006 PROTECTIVE CAP 2410508006 141 1
2 464 633 002 COMPRESSION SPRING 2464633002 200 1
1 461 314 322 DISTANCE PIECE 1461314322 202 1
1 463 300 316 HEXAGON NUT 1463300316 206 1
2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1
1 464 651 460 COILED SPRING 1464651460 220 1
1 461 021 621 SUPPORT PLATE 1461021621 235 1
1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2
0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1
1 464 477 302 BLADE TERMINAL 1464477302 242 1
1 463 314 306 FLANGE NUT 1463314306 243 1
1 460 105 312 FLAT SEAL RING 1460105312 251 1
2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2
1 466 434 324 COUPLING HALF 1466434324 270 1
2 410 508 006 PROTECTIVE CAP 2410508006 285 1
1 461 900 616 CONTROL LEVER 1461900616 289 1
1 461 900 615 CONTROL LEVER 1461900615 289 1
1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1
1 460 522 328 SPRING SEAT 1460522328 325 1
1 460 522 304 SPRING SEAT 1460522304 329 1
1 460 100 893 PLAIN WASHER 1460100893 346 1
2 911 222 700 HOLLOW BOLT 2911222700 353 1
2 911 222 700 HOLLOW BOLT 2911222700 357 1
1 460 105 313 FLAT SEAL RING 1460105313 358 2
1 460 105 313 FLAT SEAL RING 1460105313 364 2
1 460 793 379 CONNECTING PIPE 1460793379 365 1
1 461 903 310 CONTROL LEVER 1461903310 388 1
1 460 100 199 SPACER RING 1460100199 389 1
2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2
1 460 210 322 O-RING 1460210322 392 1
1 463 414 306 LOCKING SCREW 1463414306 393 1
1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1
2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1
SELECTION GROUP SHIM 452 3
1 464 616 963 COMPRESSION SPRING 1464616963 453 1
1 463 219 304 CONTROL SPOOL 1463219304 455 1
1 460 505 308 CLOSURE CAP 1460505308 471 1
1 463 126 333 SPHERICAL BOLT 1463126333 496 1
1 463 314 309 FLANGE NUT 1463314309 499 1
2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1
1 463 315 307 HEXAGON NUT 1463315307 580 2
1 465 134 967 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134967 800 1
1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1
1 460 591 313 SEALING CAP, RED 1460591313 808 1
2 420 580 005 SEALING CAP, RED 2420580005 809 1
0 460 414 208
REPLACING PARTS:
1 466 110 653 CAM PLATE 1466110653 29 1
1 467 135 999 HYDRAULIC STOP 1467135999 67 1
2 463 461 002 SCREW PLUG 2463461002 130 1
2 463 461 001 BLEEDER SCREW 2463461001 132 1
1 464 651 452 COILED SPRING 1464651452 220 1
0 330 001 042 PUSHING ELECTROMAGNET 0330001042 240 1
2 410 508 006 PROTECTIVE CAP 2410508006 285 2
1 461 335 346 CONTROL LEVER 1461335346 388 1
1 463 300 320 HEXAGON NUT 1463300320 422 1
1 460 505 323 SECURING CAP 1460505323 435 1
2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 446 2
1 464 616 340 COMPRESSION SPRING 1464616340 453 1
1 463 315 307 HEXAGON NUT 1463315307 580 1
1 467 010 547 PARTS SET CLOSURE CAP 1467010547 808 1
1 460 590 302 CLOSURE CAP 1460590302 829 1
Pages:
